Which OEM battery packs have 102-108S configuration?
- Has thanked: 35 times
- Been thanked: 32 times
Hi, looking into which battery packs have higher than the usual 96S cell configuration, especially would like to look at 102-108S packs. I know iPace has 108S, eNiro 98S. Anything else you know of?
- bexander
- Has thanked: 71 times
- Been thanked: 97 times
Re: Which OEM battery packs have 102-108S configuration?
The first gen e-Up (18.7kWh) battery has 102S.
- Has thanked: 76 times
- Been thanked: 219 times
The Peugeot 208e/Corsa-E/whatever else PSA puts those in 50kWh packs are 108s.
the middle size IDx/Enyaq/Q4 battery is 108s.
The small (48kwh) battery uses 8 modules in a 12s config giving 96S
The medium (58kwh) uses 9 modules in a 12s config giving 108S
The large (77kwh) uses 12 modules in a 8s config giving 96S
- EV_Builder
- Been thanked: 37 times
Taycan = 198S
