I have been investigating why charging using a Leaf PDM hasn't been working. It turns out that the main reason is that the PDM is designed to be used with a Type 1 EVSE, but has been put in a vehicle with a Type 2 socket.
The CP protocol is the same, but the PP protocol is different.
Would anyone be able to point me to a circuit to allow a Type 2 EVSE (and vehicle socket) to be used with a Type 1 charger?
Using a type 2 EVSE with a type 1 charger [SOLVED]
- Has thanked: 91 times
- Been thanked: 517 times
Re: Using a type 2 EVSE with a type 1 charger
I wasn't aware they differed? Got any links to details? I thought both was J1772?
- catphish
- Has thanked: 99 times
- Been thanked: 197 times
That's actually a good question, and I'm not entirely sure about the answer. Type 1 has a release switch, and type 2 has current capacity detection. Also some vehicles have resistors in the vehicle, and some don't.
I think the only thing that differs, is the PP having a resistance on it for the cable capacity. When I made my type 2 to type 1 cable for public charging, I had to put a resistor in the type 2 side for the lower of the cable rating and the connector ratings. This didn't get connected to the PP line on the cable towards the type 1 side.
Looking at the wikipedia page I used to implement J1772
https://en.wikipedia.org/wiki/SAE_J1772
https://en.wikipedia.org/wiki/SAE_J1772 ... ircuit.svg
Only the car is looking at the PP signal, though maybe some untethered EVSE's might also look at it to adjust the PWM accordingly?
Does the socket have any resistance between PP and PE?
- Has thanked: 329 times
- Been thanked: 847 times
Do you have a type one port to check if it has a pull down?
Type one reference found online. Type 2 cable plug resistances What you need to do is spoof the resistances so it ends up matching the type 1 values.
- catphish
I've only just seen this reply. After getting some proper sleep I've realised the problem is quite obvious:
Type 1: 120Ω = connected, 480Ω = disconnect switch pressed
Type 2: 220Ω = 32A cable, 680Ω = 16A cable
So I'd have to consider a circuit like this to spoof a 120 ohm load when any EVSE is connected. The charger is represented by +5v and the EVSE is represented by the 680Ω resistor.
- Screenshot at 2022-12-18 14-07-40.png (7.52 KiB) Viewed 4857 times
Indeed something that simple would work, the remaining question is does the PDM control a locking motor?
- catphish
Re: Using a type 2 EVSE with a type 1 charger [SOLVED]
It turns out that the Leaf PDM supports type 2 PP lines without this hack. The reason mine wasn't working is because the PE line was disconnected / floating!
I am currently doing a similar conversion as catphish.
I use a Leaf Gen 2 PDM controlled by Resolve EV.
It comes with a type 1 socket which I changed to type 2.
Originally, the CP signal (between the PDM and the type 1 socket) is also connected to the ground (PE) via a 2.7kOhm resistance.
Is there any modification to do on CP or PP to make the Leaf PDM and external type 2 plug communicate properly?
(My PE is already properly grounded to the vehicle chassis)
Thanks in advance to any expert which may have such knowledge
Best,
Max
Best,
Max
