Hi!
Is it anyone that has played with regen and achived one pedal driving?
I would like it to work but when I tried I couldnt get the regen to work under like 5kmh. Under that the car was free rolling, I would like to have it so the car actually stops and can even hold the car at stand still on a small slope.
Anyone with tips?
One pedal driving.
- Has thanked: 145 times
- Been thanked: 368 times
Re: One pedal driving.
Doh! You need to have a pedal range without torque near 0 so motor would not lock your wheels before stopping. Very dangerous in winter.Joxson wrote: ↑Mon Dec 12, 2022 9:17 pm Hi!
Anyone with tips?
I use a single pedal throttle even though i use a regen pot. This regen pot i can actively set but it remains on that setting. When i release throttle motor will regen. I do not use brake switch regen. Throttle release is enough for me. I use brake pedal only for mechanical effect.
- catphish
- Has thanked: 99 times
- Been thanked: 195 times
You can change the regen settings to work all the way down to stationary, it may or may not work smoothly, but worth a try. You should also experiment with the hill hold function, but I haven't been able to make it work myself.
A few improvements probably need to be made to openinverter's low speed control before this will work exactly the way you want it do. I hope to do some work on this soon, though I will initially be focusing on the opposite of what you want, constant forward torque like an automatic vehicle, but I'll keep your suggestion in mind for my testing.
Its only a summer car so it wouldnt be a problem.arber333 wrote: ↑Mon Dec 12, 2022 9:24 pm Doh! You need to have a pedal range without torque near 0 so motor would not lock your wheels before stopping. Very dangerous in winter.
Can you explain regen pot?
Best Regards
Joachim Westerlund
Joachim Westerlund
Aaah, will have to look in to the settings more.catphish wrote: ↑Mon Dec 12, 2022 9:26 pm You can change the regen settings to work all the way down to stationary, it may or may not work smoothly, but worth a try. You should also experiment with the hill hold function, but I haven't been able to make it work myself.
Sounds good!
Best Regards
Joachim Westerlund
Joachim Westerlund
