Shunt needed with OI board?
ardillolambo
Has thanked: 4 times
Post by ardillolambo »
Guys,
I'm panning using a custom digital dash board to display info such as speed, temperature and all that kind of things....can I get all that data from the OI inverter board or do I need a shunt resistor?
Been thanked: 413 times
Re: Shunt needed with OI board?
ardillolambo wrote: Wed Dec 07, 2022 2:14 pm Guys,
Hm... OI can output CAN data stream. But i dont know if you can directly use the DC current data. Maybe not really accurate...
Speed and temp info is there and can be slaved to CAN.
The DC current figure is as accurate as the current sensors are calibrated, That said it doesn't include miscellaneous currents like DC/DC, heater etc. Better source current from the BMS (or a shunt)
ardillolambo
johu wrote: Wed Dec 07, 2022 4:42 pm The DC current figure is as accurate as the current sensors are calibrated, That said it doesn't include miscellaneous currents like DC/DC, heater etc. Better source current from the BMS (or a shunt)
Johu
Any particular shunt that you will recommend for a dual motor set up?
