IPace Front Motor Hacking
Jaguar / Landrover hardware hacking
nkiernan
Has thanked: 514 times
Been thanked: 95 times
Re: IPace Front Motor Hacking
Post by nkiernan »
I know there have been a lot of other projects on the go so the big cat project has been on the back burner. In the last video there looked like good progress on the inverter reverse engineering and the next step might have been some test drop in boards. Wanted to check if there were any test boards in the end or if the new Zombieverter has any relevance to these? (I'm presuming the project got paused just before this)
I've been looking back at the I-pace motors vs the Tesla Model 3 front and rear motors, as the I-Pace size and shape fit where Tesla won't. From what I'm seeing though, it looks like limited slip diff function is achieved through the brakes and there isn't a LSD option in or for the I-Pace setup, which makes them a less use for 4x4. Wondering if anyone can confirm if they've played with one? The concentric gear/motor design gives only a basic diff function.
Also wondered if its known if the front and rear inverters are the same, and if there was a drop in board, the same board would suit both? I know this thread is for the front, but seems the front and rear might be the same?
Been thanked: 1114 times
I have no information on the rear. Project is not dead but on pause due to impending house move etc. I have fully reverse engineered the oem inverter board so its just a design and test stage remaining.
nkiernan
Post by nkiernan »
Jack Bauer wrote: Mon Aug 09, 2021 9:41 am I have no information on the rear. Project is not dead but on pause due to impending house move etc. I have fully reverse engineered the oem inverter board so its just a design and test stage remaining.
Thank you for the update
Mxa24
Post by Mxa24 »
Hey Damien,
How are you? :)
Has there been any progress made recently on the board for the iPace inverter?
I quite like this inverter as the board swap looks relatively simple and the unit is it's own enclosed unit. So ideal if it should be placed a bit further away from the motor.
If it takes a bit longer, would it be possbile to publish the pin-out of the gate driver board? Then one could solder a standard Brain Board in with flying leads.
Thank you very much,
Max
Been thanked: 1913 times
Damien is currently pausing from the forum, maybe someone else knows?
SuperV8
Has thanked: 67 times
Been thanked: 14 times
Post by SuperV8 »
nkiernan wrote: Sun Aug 08, 2021 5:10 pm I know there have been a lot of other projects on the go so the big cat project has been on the back burner. In the last video there looked like good progress on the inverter reverse engineering and the next step might have been some test drop in boards. Wanted to check if there were any test boards in the end or if the new Zombieverter has any relevance to these? (I'm presuming the project got paused just before this)
Looking at the I-Pace parts catalogue - the same part numbers listed against the front and rear inverters. Looks like the latest OE number for both front and rear inverters supersede to:
T4K20014 (J9D314G138AL) so yes front and rear inverters are the same.
Seems good value for 200hp? with some less than £500 - but that is without inverter. Inverters seem to be starting at £150 - 1/3 the price of a used M3 motor.
I agree a mechanical LSD would be difficult - AAM also make the rear motor for the AMG GT 63 E which is the same power! and same inline/axial configuration - with an LSD!
I Pace motor:
Gear ratio =9.04
Max rpm 13,000
Axle torque peak 3150Nm
Torque peak 348Nm
Power peak 147kW
Weight 73.8kg
There is also AAM casting branding - which is American Axle Manufacturing
Designed in Sweden, Manufactured in Poland.
I'm baaaack :)
St0rk
Post by St0rk »
Very happy to see you picking up this thread again!
Have a couple IPace motors (both front and back) myself, and was hoping OI would be a good match. Will follow this closely.
I am very new to this subject, but keen on learning and in a workplace with a vast knowledge base.
Let me know if I can be of any help with getting these units paired up.
Cheers!
crasbe
Has thanked: 58 times
Been thanked: 180 times
Post by crasbe »
I started a wiki page about the drive unit(s): https://openinverter.org/wiki/Jaguar_I-Pace_Drive_Unit
Any contributions are welcome, it needs a lot of work still.
The rear drive unit only has four mounting holes, two at the front and two at the rear. I'll try to get some measurements soon, also in relation to the CV axle locations.
Perhaps also interesting: The CV axle seals are often incomplete, there is a plastic ring that is part of the seal and on the long CV axle it gets stuck because the sealing surface has 1mm thinner diameter than the part further out and on the short CV axle it sometimes gets lost too.
steveknox
Has thanked: 23 times
Been thanked: 20 times
Post by steveknox »
Hello,
Does anyone have dimensions of the front or rear motors?
Steve
Mazda RX-8
GS450h Running Gear
Outlander Charger
Renault Kangoo 36kwh pack
crasbe
Post by crasbe »
Which dimensions do you need?
steveknox
Post by steveknox »
I would like the width and diameter at the 'fattest' point.
I'm trying to determine how much modification would be required to fit it into my rx8 subframe
Mazda RX-8
GS450h Running Gear
Outlander Charger
steveknox
Post by steveknox »
I took the opportunity recently to 3D scan a front motor, uploaded by Jamie.
https://grabcad.com/library/jaguar-ipace-front-motor-1
Mazda RX-8
GS450h Running Gear
Outlander Charger
maboyce
Has thanked: 82 times
Been thanked: 7 times
Post by maboyce »
I have added a link to the scan in the wiki.
PCB placement complete. Now gotta start tracking.
Board tracked and passed basic drc. 3d printing a test piece for physical fit checks.
It actually fits.
steveknox
Post by steveknox »
Great progress!
Mazda RX-8
GS450h Running Gear
Outlander Charger
V1 design now on github : https://github.com/damienmaguire/Jaguar ... ont/FDU_V1
I'll order some prototypes tomorrow.
On the basis of zero feedback I take it to mean the design is perfect so proceeded to order 10 pieces.
In production.
steveknox
Post by steveknox »
Nice one. It will be great to have another option. This is a consideration for the 911 if the SDU doesn't fit.
Mazda RX-8
GS450h Running Gear
Outlander Charger
iPace boards arrived. Testing in progress. Will try and write some sw soon to do a bit of basic testing of pwm etc
Time for some more bad news. The correct ffc connector is the Kyocera 046810650020846+T
https://www.mouser.ie/ProductDetail/KYO ... IFjA%3D%3D
