Investigate Zombieverter VCU GS450H Problem
Create a thread for each item that needs working on by the community
Been thanked: 1139 times
There have been several reports of a problem with the Lexus GS450H module in the Zombieverter VCU failing to provide smooth throttle response. e.g. here : viewtopic.php?p=48603#p48603
To date in order to solve this I purchased a GS450H drivetrain, removed it from d donor car, setup a test bench and got the firmware back into a working state on the DM_Work branch of the github repo here : https://github.com/damienmaguire/Stm32-vcu
Next, this system was fitted to my BMW E39 project :
and subsequently road tested at full (360v nominal) voltage without being able to observe this problem :
As I have a ton of projects on the go and am unable to reproduce the problem I am asking the greater openinverter community for assistance in diagnosing and fixing this problem in whatever form it takes. It has also been reported that older software does not have this problem so its at least 95% certain to be a software problem.
Requirements :
-Identify the root cause.
-Apply a fix
-Test the fix works in a vehicle
-Submit the fix on Github or on the forum so everyone can benefit and understand.
steveknox
Has thanked: 23 times
Been thanked: 20 times
Re: Investigate Zombieverter VCU GS450H Problem
Post by steveknox »
I'll be ready to do some road testing in the coming weeks. I was going to use the old VCU but i'll wire up the zombieverter instead and report back anything that I find.
Mazda RX-8
GS450h Running Gear
Outlander Charger
Renault Kangoo 36kwh pack
et0
Has thanked: 15 times
Been thanked: 6 times
Post by et0 »
