[DRIVING] Der Panzer Tesla Powered BMW E31
Re: Der Panzer Tesla Powered BMW E31
Looks good Mr Bauer!
I was also thinking maybe we could get BT functionality into Johannes' BMS at some point. The TorquePro app looks quite good.
- Has thanked: 75 times
- Been thanked: 696 times
Making nice progress on the bms :
BMS Status : 5 Error | AC Present | 96
Out:0000 Cont:0000 In:0010
Modules: 13 Cells: 96 Strings: 1 Voltage: 366.714V Avg Cell Voltage: 3.816V Low Cell Voltage: 3.547V High Cell Voltage: 3.845V Delta Voltage: 298mV Avg Temp: 0.131C
Module #1 23.01V Cell0: 3.84V Cell1: 3.83V Cell2: 3.84V Cell3: 0.00V Cell4: 3.84V Cell5: 3.83V Cell6: 3.84V
Temp 1: 15.64
Module #2 30.70V Cell7: 3.84V Cell8: 3.84V Cell9: 3.84V Cell10: 3.84V Cell11: 3.84V Cell12: 3.84V Cell13: 3.84V Cell14: 3.84V
Temp 1: 15.57
Module #3 30.71V Cell15: 3.84V Cell16: 3.84V Cell17: 3.84V Cell18: 3.84V Cell19: 3.84V Cell20: 3.84V Cell21: 3.84V Cell22: 3.84V
Temp 1: 16.09
Module #4 30.70V Cell23: 3.84V Cell24: 3.84V Cell25: 3.84V Cell26: 3.84V Cell27: 3.84V Cell28: 3.84V Cell29: 3.83V Cell30: 3.84V
Temp 1: 17.19
Module #5 30.72V Cell31: 3.84V Cell32: 3.84V Cell33: 3.84V Cell34: 3.84V Cell35: 3.84V Cell36: 3.84V Cell37: 3.84V Cell38: 3.84V
Temp 1: 15.54
Module #6 30.70V Cell39: 3.84V Cell40: 3.84V Cell41: 3.84V Cell42: 3.84V Cell43: 3.84V Cell44: 3.84V Cell45: 3.83V Cell46: 3.84V
Temp 1: 15.64
Module #7 30.69V Cell47: 3.84V Cell48: 3.84V Cell49: 3.84V Cell50: 3.84V Cell51: 3.81V Cell52: 3.84V Cell53: 3.84V Cell54: 3.84V
Temp 1: 17.10
Module #9 30.71V Cell55: 3.84V Cell56: 3.84V Cell57: 3.84V Cell58: 3.84V Cell59: 3.84V Cell60: 3.84V Cell61: 3.82V Cell62: 3.84V
Temp 1: 14.11
Module #10 30.68V Cell63: 3.84V Cell64: 3.84V Cell65: 3.84V Cell66: 3.84V Cell67: 3.84V Cell68: 3.80V Cell69: 3.84V Cell70: 3.84V
Temp 1: 14.96
Module #11 30.67V Cell71: 3.82V Cell72: 3.81V Cell73: 3.84V Cell74: 3.85V Cell75: 3.84V Cell76: 3.84V Cell77: 3.83V Cell78: 3.83V
Temp 1: 16.97
Module #13 22.73V Cell79: 3.83V Cell80: 3.84V Cell81: 3.84V Cell82: 0.00V Cell83: 3.74V Cell84: 3.74V Cell85: 3.74V
Temp 1: 13.66
Module #14 22.24V Cell86: 3.74V Cell87: 3.74V Cell88: 3.55V Cell89: 0.00V Cell90: 3.74V Cell91: 3.74V Cell92: 3.74V
Temp 1: 14.37
Module #15 22.44V Cell93: 3.74V Cell94: 3.74V Cell95: 3.74V Cell96: 0.00V Cell97: 3.74V Cell98: 3.74V Cell99: 3.74V
Temp 1: 16.84
Low Range 16339.73mA 93% SOC 42227.88mAh
Temp 1: 15.64
Temp 1: 15.57
Temp 1: 16.09
Temp 1: 17.19
Temp 1: 15.54
Temp 1: 15.64
Temp 1: 17.10
Temp 1: 14.11
Temp 1: 14.96
Temp 1: 16.97
Temp 1: 13.66
Temp 1: 14.37
Temp 1: 16.84
- Has thanked: 264 times
- Been thanked: 717 times
Oh its counting your SOC
Coding is still a bit basic, there is no drift for miss counting except at the very top end.
Wonder how close the SimpBMS is to your other system.
- Has thanked: 145 times
- Been thanked: 369 times
I just found out i still have some code from Dimitri that is using BT with Torque pro. If you like you can program your chip with it and try to use torque
I use USBASP programmer with AVRDUDE software. There is 6 pin header on the board, I use pogo pins, but you can solder pin header or whatever you want. I use these command lines as example, first one unlocks security bit and sets fuses, second flashes code and locks it
avrdude.exe -F -Cavrdude.conf -v -patmega328p -P usb -c usbasp -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDA:m -Ulfuse:w:0xFF:m
avrdude.exe -F -Cavrdude.conf -v -patmega328p -P usb -c usbasp -Uflash:w:SOC_Gauge_V4_TQ_450V.hex:i -Ulock:w:0x0F:m
There are two codes in rar file. one is normal AT serial code, the other is TQ code.
Also my board is set to max 350Vdc so i use external 500K trim pot set at 325K and i get correct voltage.
- EV display code.rar
- (30.42 KiB) Downloaded 466 times
- Kevin Sharpe
- Been thanked: 9 times
some nice views of Der Panzer at Fully Charged Live (start at 4:46)
Opensource also gets a shout out at 6:40
- Kevin Sharpe
very shiny Panzer getting ready for a magazine photo shoot
- Kevin Sharpe
"Today’s shoot for Performance BMW was unusual..."
https://twitter.com/pmcgphotos/status/1 ... 96323?s=20
- Kevin Sharpe
Fabulous article in SpeedHunters magazine
Converted: The Tesla-Powered BMW 8 Series (here)
When I asked Damien if there was any advice he would give to others who are also interested in going electric, he said this: “This is all stuff that you can do in your shed or at home as safely as wiring a plug or working on a high pressure fuel system. You still get your hands dirty. They’re still cars.”
P.S.Mangelsdorf
- Has thanked: 290 times
- Been thanked: 330 times
That's a great quote.Kevin Sharpe wrote: ↑Sat Aug 15, 2020 12:12 pm When I asked Damien if there was any advice he would give to others who are also interested in going electric, he said this: “This is all stuff that you can do in your shed or at home as safely as wiring a plug or working on a high pressure fuel system. You still get your hands dirty. They’re still cars.”
- JaniK
- Has thanked: 92 times
- Been thanked: 14 times
Wow cool writeup on speedhunters! Congratulations Damien!
Thanks folks. I'm still in quite a bit of shock about it. The article was originally supposed to appear in Performance BMW magazine but I guess the grinder cut, mig welded mild steel didn't exactly spin their turbine. Having it on Speedhunters feels like winning the lottery:)
The comments offer an interesting insight into the pervasive myths that still surround conversions. "Informed ignorance" I call it. Goes like this :
" I know xxx about ev conversion, therefore I have no reason to test to see if xxx is actually true".
Sort of like an anti scientific method:)
- TheSilverBuick
- Has thanked: 3 times
Saw the article on Twitter, good stuff!!
- Maker_of_Things
I found and read the article last night.
Really well done!
Really well done!
Alfred Chow - Maker of Things.
My Skoda Octavia conversion blog
Checkout this months Perfromance BMW magazine:)
Almost lost the Panzer last weekend :
nkiernan
- Has thanked: 442 times
- Been thanked: 87 times
Bit of an eye opener this video!!! Thanks for sharing. Glad to hear we're going to see more of the Panzer soon though, this is the car that started me on my conversion journey, all 113 panzer youtube videos over two weeks (nearly got evicted for it)
- janosch
- Has thanked: 98 times
- Been thanked: 106 times
- mark
- Has thanked: 14 times
- Been thanked: 3 times
Scary stuff! Glad to see it resulted in minimal damage. As you said, very lucky indeed. Looking forward to v2, and how it's put together with the current options available.
Wait you just had them under the car and not enclosed? Must have been corrosion or something into the plug wiring.
