I read these heaters fails, maybe I got bad one? Is there any way to confirm? Of course I installed this under the battery, so almost impossible to remove.
Really soon I need to get some different heater as its getting colder... Maybe CAN controlled Mitsubishi could be one?
I send wakeup 0x100 only once and rest messages listed on https://openinverter.org/wiki/Chevrolet ... ter_Heater are sent one message at a time in a loop every 10ms each (tried 5ms too), so all messages are send every 100ms (or 50ms if message send every 5ms).
I did try ZombieVerter heater messages with same results.
Here is what heater will send back in HEX:
Data from ID: 13FFE09D: 0 0 0 0 0 0 0 0
Data from ID: 1047809D: 0 0 40 0 0 0 0 0
Data from ID: 63E: 1 64 0 0 0 0 0 0
Data from ID: 10440000: 0 0 50 0 0 0 0 0
Data from ID: 1047809D: 0 0 51 0 0 0 0 0
Data from ID: 1047809D: 0 0 52 0 0 0 0 0
Data from ID: 1047809D: 2 0 52 0 0 0 0 0
..so after wakeup only these have non-zero bytes:
..clip..
0x1047809D byte 2 seems to be some kind of counter, it will rise slowly higher, nothing else changes.
If I do not send keepalive message 0x621 after wakeup, heater will send this message six times and go back to sleep, as predicted:
From this video heater should send more non zero messages when heating:
