There is a reasonably mature python library called canopen that looked like it might be a good base. Unfortunately I've run into a bit of a problem with the implementation of CANopen SDO in openinverter. It seems that the upload/download semantics have been inverted from the standard implementation. For example, a simple fetch of the "boost" parameter would look something like:
network = canopen.Network()
network.connect(bustype='socketcan', channel='can0', bitrate=500000)
network.check()
# Add a node with corresponding Object Dictionaries
dict = canopen.ObjectDictionary()
dict.add_object(canopen.objectdictionary.Variable('boost', 0x2000, 0x0))
node = canopen.BaseNode402(1, dict)
network.add_node(node)
# "Upload" a value from the remote node
print("remotevalue:", node.sdo.upload(0x2000, 0))
40 00 20 00 00 00 00 00
22 00 20 00 00 00 00 00
node.sdo.download(0x2000, 1, b'\x80\x0C\x00\x00')Code: Select all
23 00 20 01 80 0c 00 00
40 00 20 01 80 0C 00 00I've cross checked the python canopen library with Wireshark's CANopen dissector and the open source canopen-stack firmware stack and I believe it is doing the right thing. It should be possible to use the "CiA 301 - CANopen application layer and communication profile" spec but it's a pretty impenetrable industry spec and I found it difficult to follow.
Not sure what to do here. Main options seem to be:
- Leave openinverter as-is, fork and heavily modify the python canopen library (it does a lot of useful stuff) and create a new Wireshark dissector
- Fix openinverter to implement the standard so as to use existing tools but break all existing users (are there any?)
I'm leaning towards the first but it is a ton of non-standard work. CANopen is an over-complicated hot mess and I'm not sure it makes sense to use it as a guide for the other command-and-control requests needed to replace the serial commands. Thoughts?
