ISA IVT-S
Has thanked: 82 times
Been thanked: 422 times
ISA IVT-S
I've got one of these shunts fitted and reading current and ampseconds from it, the ampseconds are counting up as expected but not saved across resets, it's back down to 0 amp seconds for example.
https://www.isabellenhuetteusa.com/wp-c ... _V1.02.pdf The datasheet is difficult to read but says
"The log data are continually stored, with an interval of 15 minutes if the IVT-S is configured in run-mode.
In case of a sensor reset, the last stored logdata will be recovered."
Does anyone know if there's a way of storing the current measurements right before shutdown as to not lose up to 14 minutes and 59 seconds of usage measurements? STORE only mentions measurement configurations.
Isaac96
Re: ISA IVT-S
Post by Isaac96 »
Hmm this is quite a question. I thought the sensor always reset to zero, guess I'll have to rework my ISA-based SOC meter.
So you want to send a CAN message so that it saves the last ampsecond readings before shutdown. I don't see anything for that in the manual either, nor for the older ISA version (ISA-MOD).
Could you have an external device do the job? I've just learned about FRAM chips for nonvolatile storage -- one guaranteed 10 trillion write cycles. Then reset the shunt on powerup and tell all other modules what the 'offset' is relative to ISA.
Re: ISA IVT-S
Mine always seems to reset to zero. Damien just used permanent 12v to power the shunt, tempted to just do that.
Has thanked: 134 times
Been thanked: 335 times
Re: ISA IVT-S
Bigpie wrote: Sun Jan 09, 2022 8:28 am Mine always seems to reset to zero. Damien just used permanent 12v to power the shunt, tempted to just do that.
I would think SOC meter needs to always be powered on since there are elements leeching power even in standby.
Myself i am using EV Display and it is best to keep it permanently connected also to voltage measuring circuit. It has eeprom chip to save last SOC position in case of power out though...
It resets SOC to 100% when at charging highest voltage level is reached. Does ISA have a reset signal that we could command in CAN? Then it would be easy to set ISA to 100% everytime you fully charge the pack. Even with Chademo.
Any other consideration i am missing here?
Re: ISA IVT-S
It does have a reset command. I'm currently using a button in my UI to reset the counter, but it resets back to 0 when it powers off anyway.
void resetISACounters() {
  msg.id  = 0x411;
  msg.len = 8;
  msg.buf[0] = 0x3F;
  msg.buf[1] = 0x00;
  msg.buf[2] = 0x00;
  msg.buf[3] = 0x00;
  msg.buf[4] = 0x00;
  msg.buf[5] = 0x00;
  msg.buf[6] = 0x00;
  msg.buf[7] = 0x00;
  bmscan.write(msg, settings.veCanIndex);
I don't have anything connected to HV when the main contactors are open so shouldn't be any leeching.
I'm going to change the shunt to permanent 12v and have my charging code reset the counters to 0 and have my SOC be calculated based on 80% of the ah rating of the pack. I think that'll do for now.
EV_Builder
Re: ISA IVT-S
Post by EV_Builder »
Is there a DBC of these ISA devices?
catphish
Has thanked: 96 times
Been thanked: 188 times
Re: ISA IVT-S
Post by catphish »
EV_Builder wrote: Wed Sep 07, 2022 12:15 pm Is there a DBC of these ISA devices?
Here's one :)
IVT-S_12082020.dbc
(37.51 KiB) Downloaded 147 times
EV_Builder
Re: ISA IVT-S
are those messages correctly muxed? can't open it with CANdb++
catphish
Re: ISA IVT-S
Post by catphish »
EV_Builder wrote: Wed Sep 07, 2022 2:16 pm are those messages correctly muxed? can't open it with CANdb++
I use this file with SavvyCAN, afraid I can't speak for its compatibility with anything else, and I didn't make it.
EV_Builder
Re: ISA IVT-S
ok no problemo will try to fix it.
