Wanted ISA Ivt-s shunt UK
Ev8
Has thanked: 41 times
Been thanked: 152 times
Post by Ev8 »
As title really can’t find one anywhere
Zapatero
Has thanked: 25 times
Been thanked: 39 times
Re: Wanted ISA Ivt-s shunt UK
Post by Zapatero »
i've got one here in Germany - i can send it to the UK of course!
Ev8
Post by Ev8 »
Please send me a message with the price
Jonr
Been thanked: 6 times
Post by Jonr »
I'm in the market for an ISA shunt - does anyone have one available or can suggest the best place to find one?
Project : GS450h into BMW 3 Series Touring?
Has thanked: 81 times
Been thanked: 242 times
Jonr wrote: Fri Sep 30, 2022 6:40 am I'm in the market for an ISA shunt - does anyone have one available or can suggest the best place to find one?
I have one shunt only from Jaguar. It is a 500A version without voltage sensing. I am offering it for 80€ + shipping?
I guess it would need to be reprogrammed too. See here:
viewtopic.php?t=1282
aot93
Has thanked: 6 times
Been thanked: 43 times
Post by aot93 »
I contacted the UK distributor for these.
They came back with £288.10ea plus vat for 10.
In stock at manufacturers.
So probably the same as getting from existing EU suppliers.
4markowen
Has thanked: 21 times
Post by 4markowen »
https://www.testco-inc.com/search/manuf ... /mId:20907
if the £ pound hadn't tanked against the $ these would be reasonably similar in price including shipping, etc.
Seems getting one at the moment is around £300.
Jonr
Post by Jonr »
Today, I took delivery of a power pack from a BMW 530e which apparently includes a shunt..... could the ZombieVerter be enhanced to support this shunt in addition to the ISA, assumng they are both controlled CAN messages?
Jonr
Post by Jonr »
Jonr wrote: Fri Sep 30, 2022 10:12 pm Today, I took delivery of a power pack from a BMW 530e which apparently includes a shunt..... could the ZombieVerter be enhanced to support this shunt in addition to the ISA, assumng they are both controlled CAN messages?
EDIT:
I've just realised there is the mapping function on the ZombieVerter
https://openinverter.org/wiki/File:Spot_values.png
Has anyone used this to be able to use the BWM shunt in place of the ISA shunt?
If so, how?
There is also LEM CAB500 current sensor on can bus. They can be found in Outlander packs...
Ev8
Post by Ev8 »
Ok I now have what I needed thanks
larsrengersen
Has thanked: 9 times
Been thanked: 24 times
Post by larsrengersen »
The beauty / advantage of the IVT is that some models (including the one used with the Zombiverter) that can measure both voltage and current. I have the 1000A in stock.
For current only you can use cheaper sensors like this current only IVT or the CAB by LEM or others perhaps.
But then the question is: how to measure voltage and get it send on the CAN bus?
Plus of course the firmware change needed in the Zombiverter.
asavage
Has thanked: 300 times
Been thanked: 111 times
Post by asavage »
4markowen wrote: Fri Sep 30, 2022 9:07 am https://www.testco-inc.com/search/manuf ... /mId:20907
IDK, a IVT-S-500-U3-I-CAN1-12/24 is still USD$265, which isn't really a whole lot less than £300 in my view.
Al Savage
2014 RAV4 EV
NissanDiesel
FFMan
Has thanked: 8 times
Been thanked: 47 times
Post by FFMan »
I'm also looking for a shunt for SOC calculation. I have a V1c board not zombie so will do SOC on arduino based on data I harvest.
As i understand it SOC is based upon measure Amp-seconds. I can get voltage from the Outlander charger can bus and I think this is pretty accurate as you might expect it to be so would this currnt only shunt suffice - it's a lot cheaper.
E46 touring
BMW 9kwh & 12kwh packs
asavage
Post by asavage »
Last week, I just received one from member pablo_mtl, USD$155 including shipping (Canada->USA).
viewtopic.php?t=1338
The one I received has a non-terminated CAN, which is more flexible for implementation (just add 120R to the back of your CAN connector, if you need termination at the shunt).
Al Savage
2014 RAV4 EV
NissanDiesel
jcwright45
Post by jcwright45 »
Anyone still in the market for shunts? I have 2
TonyBM
Post by TonyBM »
have you still got the shunts? hope so🙏
modellfan
Has thanked: 5 times
Post by modellfan »
jcwright45 wrote: Sun Jan 22, 2023 3:35 pm Anyone still in the market for shunts? I have 2
Still available? How much do you want for one?
langoo
Post by langoo »
I'm on the hunt, PM me if you have one left.
Robin Hellström
MR Electronics AB
Galileo241
Post by Galileo241 »
Hey guys, anyone here who has already tested and used their new sensor IVT 3.0?
https://www.isabellenhuetteusa.com/prod ... -0-series/
Does anyone offers the same? Can’t find it on digikey or mouser.
Appreciate your help!
jnsaff
Been thanked: 8 times
Post by jnsaff »
It looks like they only send evaluation devices out for now.
larsrengersen
Galileo241 wrote: Thu Aug 17, 2023 6:18 pm Hey guys, anyone here who has already tested and used their new sensor IVT 3.0?
They are at B2 Sample stage.
Not end user configurable yet like the normal IVT and already much more expensive.
I’m awaiting of the final product release and they will inform me once I can order those.
asavage
Post by asavage »
This fellow has three of the 300A version, @ £99 ea. and is located in the UK:
https://www.diyelectriccar.com/threads/ivt-s-can-current-sensor-shunt.209220/
I would think the 300A capacity would work OK for situations where one is adding DCFC and using the BMW i3 LIM setup or similar.
Al Savage
2014 RAV4 EV
NissanDiesel
