drift buggy + em57 + V3 johannes board
Romale
Has thanked: 308 times
Been thanked: 79 times
Post by Romale »
When this buggy started to be made from gasoline 800cc, I put there a prius gen2 mg2 motor rewound by 2 turns , modified by hall sensors and controlled by the kelly controller kls96600-8080h.
It drove like this and had two speeds:
evil neodymium :twisted:
Romale
Re: drift buggy + em57 + V3 johannes board
Post by Romale »
Then a friend asked me for a motor for his motorcycle, a second friend took away the controller and the bugs stood for a year.
Romale
Post by Romale »
Now I remembered about it, I installed a Nissan leaf motor + em57 gen2 inverter + Johannes board version 3.
All this works temporarily on a 32S nmc catl battery 120ah and has a maximum speed of more than 100km/h,
But the damn unpredictable mega regen broke my drive (watch the video, it was scary)
Romale
Post by Romale »
How to disable the flux weakening completely?
It seems to me that this will eliminate regen without control.
Has thanked: 369 times
Been thanked: 1544 times
You can set fwkp=0. It will result in less maximum speed
At the same time increase curkp to 55
Romale
Post by Romale »
johu wrote: Sun Jun 26, 2022 10:48 pm You can set fwkp=0. It will result in less maximum speed
I tried to set fwkp=0 and curkp=55, the flow attenuation did not turn off. the prius mg1 motor is gaining furious momentum on a 40 volt battery, although it should not exceed 1500 rpm.
Romale
Post by Romale »
let's continue)))
eee291
Post by eee291 »
Looks like a fun ride.
No more issues with regen?
Romale
Post by Romale »
eee291 wrote: Thu Aug 04, 2022 6:44 pm No more issues with regen?
they disappeared as soon as I raised the battery voltage three times ( 360 volts instead of 120 ) and limited the motor speed to 450 hertz. this gives 120 km/h by satellite.
Romale
Post by Romale »
it's also a "different" buggy))), on the one that at the beginning, so far it's still 120 volts. soon I will raise it to 240 or more.
eee291
Post by eee291 »
That's good to know! Looks like I will invest in the Passat after all.
