I'm getting some odd behaviour when balancing, this happened a couple times last week when I charged the battery every now and then. It has been balancing all week fine. Today I swapped out the Isashunt and his behaviour came back.
At first I thought it was another bad board, but it wasn't showing any errors. So I raised the balance threshold above all the cell voltages and the reading went back to normal.
- not balancing.png (2.32 KiB) Viewed 10620 times
When I balance two cells bounce back and forth.
- balancing 2.png (2.71 KiB) Viewed 10620 times
- balancing 1.png (2.72 KiB) Viewed 10620 times
Could this be another bad board or something else?
Edit: I believe this may be another bad board. Just measured the cells manually and the readings for those two cells when there is no balancing is off by around .2v Will swap in another one and confirm.
