Precharge and Contactor Control  [SOLVED]
Renegate2020
Re: Precharge and Contactor Control
Post by Renegate2020 »
From November 2021
E46Driver
Post by E46Driver »
Sounds like it should be reliable. I have done the same. Hope to never have to worry about it again!
ElMaco
Has thanked: 12 times
Post by ElMaco »
Was there any general conclusion to this?
Were @E46Driver’s issues related to the added peripheral equipment, or to the Leaf Gen 2 board (alt the mainboard)?
Would you advice to add a 1 sec delay to the main contractor just to be safe, or is it just needed under certain circumstances?
50 ft slow boat with Nissan LEAF EM-57, OI gen 2. FW 5.35. Dual (2P) KIA Eniro 64kWh (98S), Orion BMS2.
Has thanked: 360 times
Been thanked: 249 times
Post by jrbe »
For those of you with this early pulse, did newer versions of the code eliminate it? Trying to follow up on this for the gen 3 leaf adapter board. Looking into implementing the suggestions listed here but I don't want to add delays to the contactors if it's not an issue.
