With the plan of Leaf motor + inverter combined to Tesla M3 batteries, is it possible to use the Leaf charger/PDM? Also if it's possible to get Chademo working with non-Leaf batteries?
I looked at Resolve-EV and they stated it all needs to be Leaf hardware, including the battery. This sounds inconvenient seeing the weight and size, but I don't rule it out completely if the benefits in compatibility outrule the TM3 modules.
Zombieverter looks more attractive since I do like opensource projects.
Right now my main goal is to find a setup that would charge through Typ2 ~6kWh like the Leaf normal charger does, but ideally would want to have the possibility to upgrade to fast charging lateron (without having to replace half of the components) when the Version 1 of the build has hit the road.
EDIT: probably bit poor choice of words above, but.. I mean, I know both Resolve-EV and Zombieverter will spin the motor stack, but currently looking for information about how easily they communicate with non-Leaf battery options and Leaf PDM (inc. fast charging in the far future)
