Behaviour in neutral
catphish
Has thanked: 96 times
Been thanked: 188 times
Post by catphish »
As far as I can see, setting the inverter to neutral disables PWM output:
      /* Shut down PWM on zero voltage request */
      if (0 == amp || 0 == dir)
         timer_disable_break_main_output(PWM_TIMER);
However there is a slightly alarming note on the wiki.
If they are both low, no current is fed to the motor making this essentially the neutral position.
Correction, this will not be a neutral position. Rather, it will be almost parking, if you turn on neutral at speed, there will be a very hard stop regen!
Please can someone confirm which is correct. I'm happy to update the wiki to remove the contradiction.
Peter
Been thanked: 9 times
Re: Behaviour in neutral
Post by Peter »
Hi Charlie. I will do a test this evening by selecting neutral when rolling with no throttle and again with a little throttle to see what happens.
For reference I have regen set up so it is only working when brake is pressed, so backing off throttle gives no regen, that way I can coast when off throttle.
Has thanked: 369 times
Been thanked: 1544 times
The behaviour is different in sine and FOC firmware. To be honest I never tested the FOC setup but I believe it is buggy due to what I see in the code and what you found on the wiki.
On the sine firmware it should work alright.
Peter
Post by Peter »
Tried selecting neutral whilst rolling with no throttle applied and did not regen, just coasted. Same with small amount of throttle. Hope that helps.
catphish
Post by catphish »
Thanks both. I also had an opportunity to test this today for myself and it seems (at least with sine firmware) I also get coasting.
Romale
Has thanked: 308 times
Been thanked: 79 times
Post by Romale »
catphish wrote: Thu Jun 30, 2022 11:27 pm
fok firmware we get a hard stop
I would be very happy to have a roll on the neutral with the foc firmware, but I did not find what setting to apply so that this became possible.
evil neodymium :twisted:
geduxaz
Has thanked: 13 times
Post by geduxaz »
What i have tested, with FOC it hits hard. i broke CV joint.
catphish
Post by catphish »
geduxaz wrote: Mon Jul 04, 2022 9:22 pm What i have tested, with FOC it hits hard. i broke CV joint.
Ouch! I'm very glad this works better in the sine version!
Romale
Post by Romale »
johu wrote: Fri Jul 01, 2022 2:37 pm The behaviour is different in sine and FOC firmware. To be honest I never tested the FOC setup but I believe it is buggy due to what I see in the code and what you found on the wiki.
what solution can be applied so that the neutral on the foc firmware also gives a free roll?
Some rework in pwmgeneration_foc.cpp. For now, just avoid neutral
js1tr3
Post by js1tr3 »
it looks like this also affects manual mode. which might explain why I can't get any PWM output when testing in manual mode. I will try connecting the forward signal and report back.
1988 Porsche 911 targa with warp11 motor. Soon to be Tesla SDU.
Oh indeed, in manual mode you also need to select a direction
Here is a version you can try that should solve neutral behaviour.
I've replaced
int dir = Param::GetInt(Param::dir);
with
int dir = frqFiltered > FP_FROMINT(10) ? Encoder::GetRotorDirection() : Param::GetInt(Param::dir);
so when the rotor is moving it will use the actual rotor direction as direction, when stationary (frq < 10Hz) it will use the intended direction. Please check if it works.
stm32_foc.hex
(133.76 KiB) Downloaded 88 times
stm32_foc.bin
(47.54 KiB) Downloaded 221 times
Romale
Post by Romale »
johu wrote: Wed Jul 13, 2022 6:19 pm Please check if it works.
It looks like I have the worst memory chip for wifi. it is constantly hanging at this stage
please, can I have a .hex file?
I have added it to the post above
Romale
Post by Romale »
johu wrote: Sat Jul 30, 2022 5:21 pm I have added it to the post above
thank you very much.
tomorrow I will definitely check on the buggy and report the results!
Romale
Post by Romale »
I have not tried high speed, but up to 35km/h turning on the neutral gives a free roll!
it works!
thank you so much for solving this problem.
if you turn it forward again in motion, it does not react to the gas pedal until I stop, then it can go again.
Great!
Yes it is programmed like that. You can raise dirchangerpm to overcome. But it will allow you to switch to reverse at speed. Not quite sure what happens then
Romale
Post by Romale »
johu wrote: Sun Jul 31, 2022 6:48 pm You can raise dirchangerpm to overcome.
ok. I will definitely test it.
I tested 500 and 1000. it works great. also, if you turn on the neutral at speed and then "forward", the pedal control returns after the speed drops to the specified value. left 500rpm. I liked it very much.
Thanks for this fix.
