chargecur parameter Topic is solved
chentron
Has thanked: 42 times
Been thanked: 10 times
chargecur parameter
Post by chentron »
Can someone please confirm that the parameter chargecur is the maximum current that will be used to charge the batteries?
so if I set chargecur = 20 .. the internal charger of openinverter v2 will only take from the grid a maximum 20 x 230= 4600 watts ?
(my setup chargemode= boost)
thanks
Re: chargecur parameter
Yes, in boost mode the current sensor measures input current
