I picked up a sdu i was wondering can the inverter be Relocated?
Obviously cover plates need to be made what size wire would be sufficient?
Tesla sdu inverter relocation??
- EV_Builder
- Been thanked: 37 times
Re: Tesla sdu inverter relocation??
I have the same question / situation. I used/plan to use 70mm2.
The acces holes to the motor poles now have a cover plate with 3 EMC clamps.
The encoder and thermistor I used 7x0.5mm2 wire.
I made alloy cover for the inverter and a cover for the engine.
I will post some pictures in my build thread when I mount it.
(Panamera build)
- qmedia2651
Yes I'm doing it for my 1991 300ce mercedes-benz conversion project. Only have 18.5 in to install sdu rear.
See pics
See pics
- qmedia2651
Update
Inverter 1 inch off set Spacer STL files
- STL_Inverter_Shims.zip
- (58.53 KiB) Downloaded 136 times
- qmedia2651
Mind sharing the cad for the endplate. After destroying two sdu inverters with my v4 board I might try with a less expensive volt inverter.
1988 Porsche 911 targa with warp11 motor. Soon to be Tesla SDU.
- qmedia2651
- qmedia2651
Tesla inverter relocation inverter HV and Encoder new cable routes.
All done on 3D printer.
- qmedia2651
I did the cover plates with a roter bit.over the inverter edge
Pcb encoder connection at motor cover
