Hyper car hybrid
Woodfie
Has thanked: 221 times
Been thanked: 96 times
Re: Hyper car hybrid
Post by Woodfie »
Have delivered a Gen Prius to Evbuilder this evening, has a dodgy battery and throws battery codes if try and drag off a mobility scooter....well not quite that bad..
May the sniffing commence.....
Just had news that are reading
120bytes MTH, 100bytes HTM. Good news!
daleread
Post by daleread »
I have started to put together some tech info and wiring diagrams fo the Prius Gen 3 to the q211 and Hylander motor, its early days yet but it is a start.
Please feel free to add to them.
Prius Gen 3 - Pin Out.xls
(342 KiB) Downloaded 361 times
Inverter Diagram Prius Gen3.pdf
(1.04 MiB) Downloaded 470 times
164620_2010_Prius_-Overall_Electric_Drawing.pdf
(1.27 MiB) Downloaded 330 times
daleread
Post by daleread »
Self Charging Hybrid
MGR in front axle of RS200
V8 4.4l in the back of RS200
GX450h MGR
Volvo/Yamaha V8
MGR Driveshaft to 100mm CV Joint Converter
MGF Hub Carriers
Mondeo Stub Axles and CV Joints
Sierra Anti Roll Bar
Lengthened (60mm) Sierra TCA's
4 Deg Castor for Power Steering
Solid Top Arm
Camber Adjustable Lower Arm
Woodfie
Post by Woodfie »
Nice progress, well done...both evbuilder a few weeks back and myself have been downed a bit by the nasty virus... have been encouraging a new push into some single cell balancer bms , and unfortunately not much metal cutting practical stuff .
Been thanked: 1122 times
A lot of very good work done here on the toyota comms. Sorry I was tied up with the house move while it was in progress.
evbuilder
Post by evbuilder »
Jack Bauer wrote: Wed Aug 17, 2022 6:08 pm A lot of very good work done here on the toyota comms. Sorry I was tied up with the house move while it was in progress.
Well it has been a while but we have got back to it recently, and have got the wheels turning on a Prius being driven on Synchronous Serial!
Just turning over from 30V power supply, but it is magic to see an OEM ECU complying with our request!
Woodfie
Post by Woodfie »
Sync serial HTM, MTH, REQ,CLK from Due arduino board with modified code from basic gs450h.
