Has thanked: 628 times
Been thanked: 1606 times
what's that Johannes? you want to see sum close ups of them joints/welds, why of course...
I think they pass the 50 foot test, flying colors!
mjc506
Has thanked: 30 times
Been thanked: 29 times
Post by mjc506 »
That looks better than a lot of OEM efforts. Great work!
Uppertown
Has thanked: 174 times
Been thanked: 36 times
Post by Uppertown »
That front mount looks well up to the job, see how you go with the rear one but I think you may need something a little stiffer than those radiator bushes. Thanks again for posting in such detail, I for one really appreciate the thought and effort you put in.👍
mjc506 wrote: Thu Mar 31, 2022 2:35 pmThat looks better than a lot of OEM efforts. Great work!
can you read the bottom row mate, no seriously thank you I appreciate the kind words
Uppertown wrote: Thu Mar 31, 2022 3:13 pmThat front mount looks well up to the job, see how you go with the rear one but I think you may need something a little stiffer than those radiator bushes. Thanks again for posting in such detail, I for one really appreciate the thought and effort you put in.👍
Literally as you were posting this I was searching AMAZON for a better universal type solution, I even reached out to Energy Suspension
Uppertown
Post by Uppertown »
Try putting "rubber mount M10" into ebay, it throws up all sorts of options in every gender you could wish for. On your side of the pond you might have to try 3/8 or similar instead of M10
nkiernan
Has thanked: 514 times
Been thanked: 95 times
Post by nkiernan »
Gregski wrote: Thu Mar 31, 2022 12:32 pm alright there it is, the transmission supported by a custom rubber mounted bracket, I won't lie it was a massive amount of work, but I am very pleased with the result - whacha all think? be gentle I have very thin skin (that's why I post on the Internets, ha ha)
Niceeeeeee 8-) Lovin' the progress :)
with the trans mount installed I was dying to try and fit the batteries back in there
Note: the sharp peak in the middle of the first battery pack is there because I have yet to cut holes for the engine crossmember bolts in the aluminum brackets, once I do that they will go down about 1 1/2"
it's gonna be s!ck
same pics from a little bit of a step backness, just to try and take all that perspectus in
I got the stock OEM Lexus GS450h two piece drive shaft so I started to work on the middle donut support mount, I believe it's crucialistic that the short shaft is perfectly in line with the transmission
I started out by divorcing the two pieces just to make the short stick lighter and easier to work with, plus mounting it by itself gave me a line of sight to test with my eyecrometer
I also chose to remove the bulky rubber doo dad off the long shaft, at the end that would mate with a Lexus differential
this is where we will welder up an "American" [pronounced: Universal] joint
next it was time to stack sum plates
for this I decided to work out front in my driveway, figuring it's been days since my last HOA complaint!
here I'm just showing off my protractor and sliding ruler skillz
Public Service Announcement
If your drill remnants look like this, this means you have a good sharp drill bit. This is Goodness!
If they look like sparkle glitter that means you have a bad dull drill bit. This is not good.
Uppertown
Post by Uppertown »
I like the "folding" battery pack, should offer a bit of useful passive safety in the event of a front end collision.
Uppertown
Post by Uppertown »
I was planning on using something like this to convert to a standard prop;
https://www.serialnine.com/product-page/ds-pro
There seem to be a few other people making them too.
Uppertown wrote: Fri Apr 01, 2022 12:43 pmI was planning on using something like this to convert to a standard prop;
that may just be too fancy for this truck
poking holes
yes, but what is he making ???
why the Mountulator 3000
... and please don't go all Anglesuxon on me, this is just a mockup
mjc506
Post by mjc506 »
Alright, I take all the "better than oem" stuff back :-) hahah
looks like both my Transmission and the short drive shaft sit at the same angle of 7.5°
I confirmed that using the latest technology, a white lazer level
and now, this...
