With Damien's boards for the Prius inverter, I believe they can be configured to use MG1 for charging, but I was wondering if it's possible for it to work the other way around, can the MG1 interface be used to provide power, similar to the V2L systems on new vehicles like the Hyundai Ioniq 5?
I'd assume that it would need to either be manually enabled via software, or when a custom a Type 2 to 240V socket via a breaker with a specific resistance of some other method, and configured with an upper limit like 2400W or 3600W (perhaps tracked by the CT clamps on the port).
Jamie
Vehicle to Load (V2L)
- Has thanked: 368 times
- Been thanked: 1536 times
Re: Vehicle to Load (V2L)
There is such a software for the Gen2 inverter: viewtopic.php?f=3&t=1368
Could be adapted to run on the second chip of the Dual Prius Gen3 board.
You do need some magnetics to filter the inverter output but otherwise it's just that.
- jalovick
- Has thanked: 10 times
- Been thanked: 7 times
I have a couple of use cases for such a device, to pull power out of a converted vehicle, but it's also looking more and more like I'll be able to use a Gen 3 Prius C/Yaris/Auris inverter with a dual gen 3 board (if there is one to fit the Prius C inverter) and use it to replace the onboard charger on a Mitsubishi i-MiEV to use as a charger, DC to DC, and AC inverter. The current on-board charger is only good for 240V 15A/3600W, I'd love to be able to charge at up to 22 kW on 3 phase. It would just need to emulate the existing CAN messages that the car expects.
- Has thanked: 134 times
- Been thanked: 335 times
I have thought a lot about our house. I recently got 5kW hybrid inverter. Its input voltage limit is 450Vdc and it is designed to work with 48V battery inhouse and it can output 5kVA of 230Vac. I think i will try to connect input to my car via solar connectors on 6mm2 wires. If that works i can further speculate on its use... Charging the car is another matter. Better done via AC i think.jalovick wrote: ↑Wed Mar 23, 2022 1:36 am I have a couple of use cases for such a device, to pull power out of a converted vehicle, but it's also looking more and more like I'll be able to use a Gen 3 Prius C/Yaris/Auris inverter with a dual gen 3 board (if there is one to fit the Prius C inverter) and use it to replace the onboard charger on a Mitsubishi i-MiEV to use as a charger, DC to DC, and AC inverter. The current on-board charger is only good for 240V 15A/3600W, I'd love to be able to charge at up to 22 kW on 3 phase. It would just need to emulate the existing CAN messages that the car expects.
Yes should be possible though I'm not sure about 22 kW. I built a charger based on Prius components and while the power electronics a definitely capable of 22 kW or more, the control loop isn't. I've taken it up to 15 kW but then "dents" from rectified 3-phase become so harsh that the breaker trips after a while.jalovick wrote: ↑Wed Mar 23, 2022 1:36 am I have a couple of use cases for such a device, to pull power out of a converted vehicle, but it's also looking more and more like I'll be able to use a Gen 3 Prius C/Yaris/Auris inverter with a dual gen 3 board (if there is one to fit the Prius C inverter) and use it to replace the onboard charger on a Mitsubishi i-MiEV to use as a charger, DC to DC, and AC inverter. The current on-board charger is only good for 240V 15A/3600W, I'd love to be able to charge at up to 22 kW on 3 phase. It would just need to emulate the existing CAN messages that the car expects.
- jalovick
While 22 kW would be ideal, anything about the standard 3.6 kW would be of benefit. 11 kW/16A may be a better target on 3 phase and 7.2 kW/32A on a single phase should be achievable?johu wrote: ↑Wed Mar 23, 2022 7:15 am Yes should be possible though I'm not sure about 22 kW. I built a charger based on Prius components and while the power electronics a definitely capable of 22 kW or more, the control loop isn't. I've taken it up to 15 kW but then "dents" from rectified 3-phase become so harsh that the breaker trips after a while.
The other alternative is to find an existing EV charger from another vehicle that has 3 phase charging and DC to DC and modify that.
Jamie
