Hyper car hybrid
Woodfie
Has thanked: 221 times
Been thanked: 96 times
Re: Hyper car hybrid
Post by Woodfie »
2006 Lexus, which have modified into a Phev, and ordered a transmission and inverter of the same model.
the numbers off inverter is G9200-30030.
evbuilder
Post by evbuilder »
daleread wrote: Wed Mar 09, 2022 9:58 pm Download from here. logic 1.2.18 (not logic 2)
https://support.saleae.com/logic-softwa ... load-links
Then you can open Damien's logfiles
Oh, trouble...
It looks like toyota updates at 5ms intervals.
It is clocked at 500kHz - and the clocks don't let up, they just blast on through continuously
So reference line is very important to get the exact right bit for the message start. I'm not sure exactly how to hook that up to chip select lines for each receiver. Might need some logic chips, or some very fast interrupts.
If you can work out what the HTM data array maps to that would be great! I don't see how to do that without recording both data lines at the same time, and probably videoing the drive and figuring out how to sync it up.
Woodfie and I have used the vcu board to decode some MTH data. Adjusting bus voltage, heat gun pointed at temperature sensors that sort of thing.
daleread
Post by daleread »
Woodfie wrote: Thu Mar 10, 2022 12:03 am Still trying to find my way around this forum procedure, not sure how to put pic up yet, work in process.
Will be reconnecting the system in a few days, and then can furnish you with the connections etc.
Same here Woolfie.
I found 2 magic buttons,
Under this window is "Attachments", you can add files and photos from there.
The second is the " quote marks in the top left to build a reply.
Its a bit like hacking :)
Looking forward to some photos, thanks for your help.
daleread
Post by daleread »
The gs450_vcu Rx and Tx the data ok, use that code, don't re-invent the wheel, do you do Arduino code?
I can unravel Damien's code for each relevant byte, and build the data array document. (has Damien already done this...?)
It will take me a few hours, but very worthwhile.
Give me a day or 2 :)
There are 13 bytes of data to make the inverter run (0,5,6,11,12,26,27,32,33,75,76,78,79)
Speed, bytes 0 75,76
MG1, bytes 5,6 11,12
MG2, bytes 26,27 32,33
CRC, bytes 78,79
I suspect the same data is in all inverters but probably grew larger through the generations
TBH, it look quite straight forward...
htm control bytes, to Inverter
// Set up control array bytes for inverter message send
void control_inverter()
  int speedSum=0;
  if(timer_htm.check())                                                 //prepare htm data
    if(mth_good)
      dc_bus_voltage=(((mth_data[82]|mth_data[83]<<8)-5)/2);            //DC Bus Votage,                  Bytes 82,83
      temp_inv_water=(mth_data[42]|mth_data[43]<<8);                    //Inverter Water Temperature,     Bytes 42,43
      temp_inv_inductor=(mth_data[86]|mth_data[87]<<8);                 //Inverter Inductor Temperature,  Bytes 86,87
      mg1_speed=mth_data[6]|mth_data[7]<<8;                             //MG1 Speed                       Bytes 6,7
      mg2_speed=mth_data[31]|mth_data[32]<<8;                           //MG2 Speed                       Bytes 31,32
    //gear=get_gear();
    mg2_torque=get_torque();                                            // -3500 (reverse) to 3500 (forward)
    mg1_torque=((mg2_torque*5)/4);                                      //Cheat
    if((mg2_speed>MG2MAXSPEED)||(mg2_speed<-MG2MAXSPEED))mg2_torque=0;  //MG2 Stopped
    if(gear==REVERSE)mg1_torque=0;                                      //MG1 Stopped
    //speed feedback
    speedSum=mg2_speed+mg1_speed;                                       //Total speed (RPM?)
    speedSum/=113;                                                      //Total Speed Calc
    htm_data[0]=(byte)speedSum;                                         //Build SpeedSum                Byte 0
    htm_data[75]=(mg1_torque*4)&0xFF;                                   //Build Torque                  Byte 75
    htm_data[76]=((mg1_torque*4)>>8);                                   //Build Torque                  Byte 76
    //mg1
    htm_data[5]=(mg1_torque*-1)&0xFF;                                   //negative is forward           Byte 5
    htm_data[6]=((mg1_torque*-1)>>8);        Byte 6
    htm_data[11]=htm_data[5];        Byte 11 = Byte 5
    htm_data[12]=htm_data[6];        Byte 12 = Byte 6
    //mg2
    htm_data[26]=(mg2_torque)&0xFF;                                     //positive is forward           Byte 26
    htm_data[27]=((mg2_torque)>>8);        Byte 27
    htm_data[32]=htm_data[26];        Byte 32 = Byte 26
    htm_data[33]=htm_data[27];        Byte 33 = Byte 27
    //checksum
    htm_checksum=0;
    for(byte i=0;i<78;i++)htm_checksum+=htm_data[i];                    //CRC
    htm_data[78]=htm_checksum&0xFF;        Byte 78, CRC
    htm_data[79]=htm_checksum>>8;        Byte 79, CRC (last byte)
mth data bytes, from inverter
  SerialDEBUG.print("MG1 - Speed: ");
  SerialDEBUG.print(mg1_speed);                                     //MG1
  SerialDEBUG.print("rpm\tPosition: ");
  SerialDEBUG.print(mth_data[12]|mth_data[13]<<8);                  //MG1 rpm                 Byte 12, 13 rpm
  SerialDEBUG.print("\n");
  SerialDEBUG.print("MG2 - Speed: ");                               //MG2
  SerialDEBUG.print(mg2_speed);
  SerialDEBUG.print(mth_data[37]|mth_data[38]<<8);                  //MG2 rpm                 Byte 37,38
  SerialDEBUG.print("Water Temp:\t");                               //Water Temperature
  SerialDEBUG.print(temp_inv_water);
  SerialDEBUG.print("c\nInductor Temp:\t" );                        //Inductor Temperature
  SerialDEBUG.print(temp_inv_inductor);
  SerialDEBUG.print("c\nAnother Temp:\t");
  SerialDEBUG.print(mth_data[88]|mth_data[89]<<8);                  //Water Temperature       Byte 88,89
  SerialDEBUG.print(mth_data[41]|mth_data[40]<<8);                  //Inductor Temperature    Byte 41,40  <<< wrong way around !
  SerialDEBUG.print("c\n");
It appears there are 8 parameters
v=pack voltage (0-700Volts)
i=current (0-1000Amps)
p=power (0-300kw)
m=mg1 rpm (0-10000rpm)
n=mg2 rpm (0-10000rpm)
o=mg1 temp (-20 to 120C)
r=mg2 temp (-20 to 120C)
q=oil pressure (0-100%)
Woodfie
Post by Woodfie »
daleread wrote: Wed Mar 09, 2022 8:23 pm How do you tell each motor separately what throttle (torque) you require?
Did you hack Damien's gs450h_vcu code to do this?
Here were the changes made to the gs450h _vcu code
2 separate throttles as described in above post.
Woodfie
Post by Woodfie »
daleread wrote: Wed Mar 09, 2022 7:56 pm
Woodfie wrote: Wed Mar 09, 2022 8:01 am Have been working with evbuilder to use a Prius gen3 inverter to install in a custombuilt hybrid roadster, as a front wheel drive, the rear has a transverse Rover type V8 of 4.5L, from a Leyland P76.
Any photos of your car? and the wiring, motor and front driveshafts and V8 and gearbox setup.
Sounds really interesting, and very similar to what I am trying to achieve.
Here are some photos of the Siris Roadster.
The Mauve one is the Q211 recipient.
Woodfie
Post by Woodfie »
Will get driveline pictures in daylight.
Front end at present is mk3 Cortina, am looking to install a double wishbone system , as yet un found...do you have any suggestions? What are you intending to use on RS200?
daleread
Post by daleread »
Nice looking car, reminds me of a TR7, but way better. Is it a production or a kit car?
I use MGTF hub carriers (classic mini) on the front on the RS200 with fabricated longer wishbones.
You can use the whole subframe from a MGF or MGTF, every thing is there for you in one lump.
I replace the hubs with Ford Fiesta 4x108 and use Audi bearings, and Wilwood 4 pot callipers.
I can share the CAD files if they are useful to you?
There are lots of photos here, scroll to the bottom of the page.
https://rsretro.smugmug.com/Chassis-Bod ... m/Chassis/
Thank you for the code, always looks simple when its done. Much appreciated.
I have been hacking into the Zombie Inverter for the Prius code, to move it into the GS450h_vcu.
I have documented the code and built a small spread sheet with the relevant byte transfers and where they are different between Lexus and Toyota.
The Prius Inverters are way cheaper than the Lexus, be great to get this working.
Here is the spreadsheet and code below that.
I am still checking through this stuff and I haven't tested it, yet.
	Function			Description		450h 		Prius		Comments
htm	To Inverter		GS450H.cpp		[80]			[100]
htm	Speed			Speed Sum		0			0
	Speed			Torque Sum Hi		76			76		75
	Speed			Torque Sum Lo		75			75		76
	MG1			Torque Req Hi		5			5
	MG1			Torque Req Lo		6			6
	MG1			Torque Req Hi		11			11
	MG1			Torque Req Lo		12			12
	MG2			Torque Req Hi		26		Reverse	26
	MG2			Torque Req Lo		27		Reverse	27
	MG2			Torque Req Hi/2 			Forward	28	new
	MG2			Torque Req Lo/2 			Forward	29	new
	MG2			Torque Req Hi		32			30
	MG2			Torque Req Lo		33			31
	Regen			Battery Hi		63			85	moved
	Regen			Battery Lo		64			86	moved
	Discharge		Battery Hi		65			87	moved
	Discharge		Battery Lo		66			88	moved
	CRC			CRC Hi			78			98	moved
	CRC			CRC Lo			79			99	moved
	Constant					4			1
	Constant					4	16	4	16
	Constant					4	37	4	41
	Constant					4	60	4	67
	Constant					25	62	4	73
	Constant					128	70	24	75
	Constant				128,255	74		136	86
	Constant							160	90
	CRC						37	78	95	98
	CRC						1	79	1	99
mth	From Inverter			[100]		[120]
	Data Rx	Inc			1
	MG1 Speed	Hi		6			6
	MG1 Speed	Lo		7			7
	MG1 rpm		Hi		12
	MG1 rpm		Lo		13
	MG2 Speed	Hi		31
	MG2 Speed	Lo		32
	MG2 rpm		Hi		37			38	moved
	MG2 rpm		Lo		38			39	moved
	Inverter Temp	Hi		41			40
	Inverter Temp	Lo		40			41
	Water Temp	Hi		42			42
	Water Temp	Lo		43			43
	Bus Voltage	Hi		82			100	moved
	Bus Voltage	Lo		83			101	moved
	Inverter Temp	Hi		86			86
	Inverter Temp	Lo		87			87
	Water Temp	Hi		88
	Water Temp	Lo		89
	CRC		Hi		78			98
	CRC		Lo		79			99
* GS450h and Prius Zombie Inverter master
* Data exchange, using htm_state
* Step 0, Read data string from the Inverter, sync pin low
* Step 1, Send setup data string to Inverter with sync pin high, or sync pin low
* Step 2, Spare
* Step 3, Calc checksum and error LED, or decode data from Inveter
* Step 4, Calc torque required data and send to Inverter
* inv_status is the data pointer
* D.R. 10th March 2022
#include "GS450H.h"
#include "hwinit.h"
#include "temp_meas.h"
#include <libopencm3/stm32/timer.h>
#include "anain.h"
#include "my_math.h"
#include "utils.h"
#define  LOW_Gear  0
#define  HIGH_Gear  1
#define  AUTO_Gear  2
static uint8_t htm_state = 0;
static uint8_t inv_status = 1;//must be 1 for gs450h
uint16_t counter;
static uint16_t htm_checksum;
static uint8_t frame_count;
static int16_t mg1_torque, mg2_torque, speedSum;
bool statusInv=0;
int16_t GS450HClass::dc_bus_voltage;
int16_t GS450HClass::temp_inv_water;
int16_t GS450HClass::temp_inv_inductor;
int16_t GS450HClass::mg1_speed;
int16_t GS450HClass::mg2_speed;
//80 bytes out and 100 bytes back in (with offset of 8 bytes).
//100 bytes out and 80 bytes back in (for Prius Support).
static uint8_t mth_data[120];
//GS450h init data
static uint8_t htm_data_setup[100]= {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,4,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,4,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,4,0,25,0,0,0,0,0,0,0,128,0,0,0,128,0,0,0,37,1};
//GS450h woeking data
static uint8_t htm_data[100]= {0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,255,0,0,0,0,0,0,0,0,0};
#if 0
// Not currently used
static uint8_t htm_data_setup_auris[100]= {0x00, 0x0E, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0x00, 0x19, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x88, 0x00, 0x00, 0x00, 0xA0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x5F, 0x01};
#endif
// 0=Prius init data (from 0 to 6)
uint8_t htm_data_init[7][100]=
{	{0,14,0,0,0,0,0,0,0,0,0,0,0,0,0,0,4,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,4,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,4,0,0,0,0,0,4,0,25,0,0,0,0,0,0,0,0,0,0,136,0,0,0,160,0,0,0,0,0,0,0,95,1},
{0,30,0,0,0,0,0,18,0,154,250,0,0,0,0,97,4,0,0,0,0,0,173,255,82,0,0,0,0,0,0,0,16,0,0,0,0,0,0,0,0,4,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,4,0,0,0,0,0,4,75,25,60,246,52,8,0,0,0,0,0,0,138,0,0,0,168,0,0,0,1,0,0,0,72,7},
{0,30,0,0,0,0,0,18,0,154,250,0,0,0,0,97,4,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,16,0,0,0,0,0,0,0,0,4,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,4,0,0,0,0,0,4,75,25,60,246,52,8,0,0,0,0,0,0,138,0,0,0,168,0,0,0,2,0,0,0,75,5},
{0,30,0,0,0,0,0,18,0,154,250,0,0,255,0,97,4,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,16,0,0,0,0,0,255,0,0,4,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,4,0,0,0,0,255,4,73,25,60,246,52,8,0,0,255,0,0,0,138,0,0,0,168,0,0,0,3,0,0,0,70,9},
{0,30,0,2,0,0,0,18,0,154,250,0,0,16,0,97,0,0,0,0,0,0,200,249,56,6,165,0,136,0,63,0,16,0,0,0,63,0,16,0,3,128,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,4,0,0,0,0,16,0,75,12,45,248,21,6,0,0,16,0,0,0,202,0,211,0,16,0,0,0,134,16,0,0,130,10}
// Clock
void GS450HClass::setTimerState(bool desiredTimerState)
    if (desiredTimerState != this->timerIsRunning)
        if (desiredTimerState)
            tim_setup(); //toyota hybrid oil pump pwm timer
            tim2_setup(); //TOYOTA HYBRID INVERTER INTERFACE CLOCK
            this->timerIsRunning=true; //timers are now running
        else
            // These are only used with the Totoa hybrid option.
            timer_disable_counter(TIM2); //TOYOTA HYBRID INVERTER INTERFACE CLOCK
            timer_disable_counter(TIM1); //toyota hybrid oil pump pwm timer
            this->timerIsRunning=false; //timers are now stopped
// Torque required map (not used)
void GS450HClass::setTorqueTarget(int16_t torquePercent)
    //map throttle for GS450HClass inverter
    this->scaledTorqueTarget = utils::change(torquePercent, 0, 3040, 0, 3500);
// 100 ms code
void GS450HClass::run100msTask(uint8_t Lexus_Gear, uint16_t Lexus_Oil)
    //update inverter status on web interface
    Param::SetInt(Param::InvStat, GS450HClass::statusFB());
    // Lexus only gearbox
    if (Lexus_Gear == 1)
        DigIo::SP_out.Clear();
        DigIo::SL1_out.Clear();
        DigIo::SL2_out.Clear();
	//set high gear
        Param::SetInt(Param::GearFB,HIGH_Gear);
    if (Lexus_Gear == 0)
        //set low gear
        Param::SetInt(Param::GearFB,LOW_Gear);
    setTimerState(true);
    //map oil pump pwm to timer
    uint16_t Lexus_Oil2 = utils::change(Lexus_Oil, 10, 80, 1875, 425);
    //duty. 1000 = 52% , 500 = 76% , 1500=28%
    timer_set_oc_value(TIM1, TIM_OC1, Lexus_Oil2);
    //update web interface with status of gearbox PB feedbacks for diag purposes.
    Param::SetInt(Param::Gear1,DigIo::gear1_in.Get());
    Param::SetInt(Param::Gear2,DigIo::gear2_in.Get());
    Param::SetInt(Param::Gear3,DigIo::gear3_in.Get());
    //send GS450H inverter temp to web interface
    Param::SetInt(Param::tmphs,GS450HClass::temp_inv_water);
    static s32fp mTemps[2];
    static s32fp tmpm;
    //in the gs450h case we must read the analog temp values from sensors in the gearbox
    int tmpmg1 = AnaIn::MG1_Temp.Get();
    int tmpmg2 = AnaIn::MG2_Temp.Get();
    mTemps[0] = TempMeas::Lookup(tmpmg1, TempMeas::TEMP_TOYOTA);
    mTemps[1] = TempMeas::Lookup(tmpmg2, TempMeas::TEMP_TOYOTA);
    //which ever is the hottest gets displayed
    tmpm = MAX(mTemps[0], mTemps[1]);
    Param::SetFlt(Param::tmpm,tmpm);
//Usart 2 DMA Transmit and Receive Section
// Write DMA data
static void dma_write(uint8_t *data, int size)
     * Using channel 7 for USART2_TX
    /* Reset DMA channel*/
    dma_channel_reset(DMA1, DMA_CHANNEL7);
    dma_set_peripheral_address(DMA1, DMA_CHANNEL7, (uint32_t)&USART2_DR);
    dma_set_memory_address(DMA1, DMA_CHANNEL7, (uint32_t)data);
    dma_set_number_of_data(DMA1, DMA_CHANNEL7, size);
    dma_set_read_from_memory(DMA1, DMA_CHANNEL7);
    dma_enable_memory_increment_mode(DMA1, DMA_CHANNEL7);
    dma_set_peripheral_size(DMA1, DMA_CHANNEL7, DMA_CCR_PSIZE_8BIT);
    dma_set_memory_size(DMA1, DMA_CHANNEL7, DMA_CCR_MSIZE_8BIT);
    dma_set_priority(DMA1, DMA_CHANNEL7, DMA_CCR_PL_MEDIUM);
    //dma_enable_transfer_complete_interrupt(DMA1, DMA_CHANNEL7);
    //dma_clear_interrupt_flags(DMA1, DMA_CHANNEL7, DMA_TCIF);
    dma_enable_channel(DMA1, DMA_CHANNEL7);
    usart_enable_tx_dma(USART2);
//DMA channel interupt 7 USART2_TX
volatile int transfered = 0;
void dma1_channel7_isr(void)
    if ((DMA1_ISR &DMA_ISR_TCIF7) != 0)
	//Interrupt Flag Clear Register
        DMA1_IFCR |= DMA_IFCR_CTCIF7;
	// Flag sucess
        transfered = 1;
    dma_disable_transfer_complete_interrupt(DMA1, DMA_CHANNEL7);
    usart_disable_tx_dma(USART2);
    dma_disable_channel(DMA1, DMA_CHANNEL7);
//DMA channel interupt 6 USART2_RX
static void dma_read(uint8_t *data, int size)
    // Reset DMA channel
    dma_channel_reset(DMA1, DMA_CHANNEL6);
    dma_set_peripheral_address(DMA1, DMA_CHANNEL6, (uint32_t)&USART2_DR);
    dma_set_memory_address(DMA1, DMA_CHANNEL6, (uint32_t)data);
    dma_set_number_of_data(DMA1, DMA_CHANNEL6, size);
    dma_set_read_from_peripheral(DMA1, DMA_CHANNEL6);
    dma_enable_memory_increment_mode(DMA1, DMA_CHANNEL6);
    dma_set_peripheral_size(DMA1, DMA_CHANNEL6, DMA_CCR_PSIZE_8BIT);
    dma_set_memory_size(DMA1, DMA_CHANNEL6, DMA_CCR_MSIZE_8BIT);
    dma_set_priority(DMA1, DMA_CHANNEL6, DMA_CCR_PL_LOW);
    //dma_enable_transfer_complete_interrupt(DMA1, DMA_CHANNEL6);
    // dma_clear_interrupt_flags(DMA1, DMA_CHANNEL6, DMA_TCIF);
    dma_enable_channel(DMA1, DMA_CHANNEL6);
    usart_enable_rx_dma(USART2);
//DMA Interrupt Serial 2
volatile int received = 0;
void dma1_channel6_isr(void)
    if ((DMA1_ISR &DMA_ISR_TCIF6) != 0)
        DMA1_IFCR |= DMA_IFCR_CTCIF6;
        received = 1;
    dma_disable_transfer_complete_interrupt(DMA1, DMA_CHANNEL6);
    usart_disable_rx_dma(USART2);
    dma_disable_channel(DMA1, DMA_CHANNEL6);
//Dilbert's code here
// Prius data exchange init
void GS450HClass::SetPrius()
    if (htm_state<5)
	htm_state = 5;		//Prius is steps 5 to 9
    	inv_status = 0;		//must be 0 for Prius (data array)
//GS450h data exchange init
void GS450HClass::SetGS450H()
	if (htm_state>4)
	htm_state = 0;		//GS450h are steps 0 to 4
	inv_status = 1;		//must be 1 for gs450h (data array)
// mth CRC
uint8_t GS450HClass::VerifyMTHChecksum(uint16_t len)
    uint16_t mth_checksum=0;
    for(int i=0; i<(len-2); i++)
		mth_checksum+=mth_data[i];
    if(mth_checksum==(mth_data[len-2]|(mth_data[len-1]<<8))) return 1;
    else return 0;
// htm CRC
void GS450HClass::CalcHTMChecksum(uint16_t len)
    uint16_t htm_checksum=0;
    for(int i=0; i<(len-2); i++)htm_checksum+=htm_data[i];
    htm_data[len-2]=htm_checksum&0xFF;
    htm_data[len-1]=htm_checksum>>8;
// Sequencer
void GS450HClass::UpdateHTMState1Ms(int8_t gear)
// GS450h Sequence, Steps 0-4 -----------------------------------------------------------
// Step 0, Read data string[100] from the Inverter, sync pin low
// Step 1, Send setup data string[80] to Inverter with sync pin high, or sync pin low
// Step 2, Spare
// Step 3, Calc checksum and error LED, or decode data from Inveter
// Step 4, Calc torque required data and send to Inverter
// Sequencer
    switch(htm_state)
    case 0:
	//read in mth data via dma. Probably need some kind of check dma complete flag here
        dma_read(mth_data,100);
 	//HAL_GPIO_WritePin(HTM_SYNC_GPIO_Port, HTM_SYNC_Pin, 0);
        DigIo::req_out.Clear();
	//Next step
        htm_state++;
    break;
    case 1:
  	//HAL_GPIO_WritePin(HTM_SYNC_GPIO_Port, HTM_SYNC_Pin, 1);
        DigIo::req_out.Set();
	// Inverter init
        if(inv_status==0)
	    // if the transfer complete flag is set
            if (dma_get_interrupt_flag(DMA1, DMA_CHANNEL7, DMA_TCIF))then send another packet
                dma_clear_interrupt_flags(DMA1, DMA_CHANNEL7, DMA_TCIF);//clear the flag.
                dma_write(htm_data,80); //HAL_UART_Transmit_IT(&huart2, htm_data, 80);
        else
	    //HAL_UART_Transmit_IT(&huart2, htm_data_setup, 80);
            dma_write(htm_data_setup,80);
	    // Wait for reply from Inverter <<<<<<<<<<
            if(mth_data[1]!=0)
                inv_status--;
        htm_state++;
    break;
    case 2:
        htm_state++;
    break;
    case 3:
        // dma_get_interrupt_flag(DMA1, DMA_CHANNEL6, DMA_TCIF);
        if(VerifyMTHChecksum(100)==0 || dma_get_interrupt_flag(DMA1, DMA_CHANNEL6, DMA_TCIF)==0)
	    //HAL_GPIO_WritePin(LED2_GPIO_Port, LED2_Pin, 1 );
            statusInv=0;
        else
	    //HAL_GPIO_WritePin(LED2_GPIO_Port, LED2_Pin, 0 );
	    //exchange data and prepare next HTM frame
            statusInv=1;
	// CRC
        mth_data[98]=0;
        mth_data[99]=0;
        htm_state++;
    break;
    case 4:
        if(gear==0) mg2_torque=0;//Neutral
        if(gear==32) mg2_torque=this->scaledTorqueTarget;//Drive
        if(gear==-32) mg2_torque=this->scaledTorqueTarget*-1;//Reverse
	// MG1 torque cheat
 	//no mg1 torque in reverse.
        if(gear==-32) mg1_torque=0;
	//post processed final torue value sent to inv to web interface
        Param::SetInt(Param::torque,mg2_torque);
        //speed feedback
        speedSum/=113;
        uint8_t speedSum2=speedSum;
        htm_data[0]=speedSum2;
        htm_data[75]=(mg1_torque*4) & 0xFF;
        htm_data[76]=((mg1_torque*4)>>8) & 0xFF;
        //MG1
        //MG2
        htm_data[26]=(mg2_torque) & 0xFF; //positive is forward
        htm_data[27]=((mg2_torque)>>8) & 0xFF;
        // regen ability of battery
        htm_data[63]=(-5000)&0xFF;
        htm_data[64]=((-5000)>>8);
        // discharge ability of battery
        htm_data[65]=(27500)&0xFF;
        htm_data[66]=((27500)>>8);
        //checksum
        htm_checksum=0;
        for(int i=0; i<78; i++)htm_checksum+=htm_data[i];
	// LED
        if(counter>100)
	    //HAL_GPIO_TogglePin(LED1_GPIO_Port, LED1_Pin );
            counter = 0;
        else
            counter++;
	// Reset to start of sequence
        htm_state=0;
    break;
/***** Demo code for Gen3 Prius/Auris direct communications! */
// Prius Sequence, Steps 5 to 9 ----------------------------------------------------------------------
// Step 5, Read data string[100] from the Inverter, sync pin low
// Step 6, Send setup data string[6][80] to Inverter with sync pin high, or sync pin low
// Step 7, Spare
// Step 8, Calc checksum and error LED, or decode data from Inveter
// Step 9, Calc torque required data and send to Inverter
   case 5:
        dma_read(mth_data,120);
	// Next step
        htm_state++;
    break;
    case 6:
	if(inv_status>5)
		// if the transfer complete flag is set then send another packet
			dma_write(htm_data,100); //HAL_UART_Transmit_IT(&huart2, htm_data, 80);
	else
		//HAL_UART_Transmit_IT(&huart2, htm_data_setup,80);
		dma_write(&htm_data_init[inv_status][0],100);
		inv_status++;
		if(inv_status==6)
			//memcpy(htm_data, &htm_data_init[ inv_status ][0], 100);
        htm_state++;
    break;
    Case 7:
	htm_state++;
    break;
    case 8:
        if(VerifyMTHChecksum(120)==0 || dma_get_interrupt_flag(DMA1, DMA_CHANNEL6, DMA_TCIF)==0)
            statusInv=0;
        else
            statusInv=1;
            dc_bus_voltage=(((mth_data[100]|mth_data[101]<<8)-5)/2);
            mg2_speed=mth_data[38]|mth_data[39]<<8;
	// Clear CRC
        mth_data[98]=0;
        mth_data[99]=0;
	// Next step
        htm_state++;
    break;
    case 9:
	// MG1 torque calc cheat
        if(gear==-32) mg1_torque=0; //no mg1 torque in reverse.
        Param::SetInt(Param::torque,mg2_torque);//post processed final torue value sent to inv to web interface
        //speed feedback
        speedSum/=113;
        //Possibly not needed
        //uint8_t speedSum2=speedSum;
	//htm_data[0]=speedSum2;
	//these bytes are used, and seem to be MG1 for startup, but can't work out the relatino to the
	//bytes earlier in the stream, possibly the byte order has been flipped on these 2 bytes
	//could be a software bug ?
        htm_data[76]=(mg1_torque*4) & 0xFF;
        htm_data[75]=((mg1_torque*4)>>8) & 0xFF;
        //MG1
        htm_data[5]=(mg1_torque)&0xFF;  //negative is forward
        htm_data[6]=((mg1_torque)>>8);
        //MG2 the MG2 values are now beside each other!
	htm_data[30]=(mg2_torque) & 0xFF; //positive is forward
	htm_data[31]=((mg2_torque)>>8) & 0xFF;
	// Drive
	if(gear==32)
		//forward direction these bytes should match
		htm_data[26]=htm_data[30];
		htm_data[27]=htm_data[31];
		htm_data[28]=(mg2_torque/2) & 0xFF; //positive is forward
		htm_data[29]=((mg2_torque/2)>>8) & 0xFF;
	// Reverse
	if(gear==-32)
		//reverse direction these bytes should match
		htm_data[28]=htm_data[30];
		htm_data[29]=htm_data[31];
		htm_data[26]=(mg2_torque/2) & 0xFF; //positive is forward
		htm_data[27]=((mg2_torque/2)>>8) & 0xFF;
	//This data has moved!
        htm_data[85]=(-5000)&0xFF;
        htm_data[86]=((-5000)>>8);
        htm_data[87]=(-10000)&0xFF;
        htm_data[88]=((-10000)>>8);
        //checksum
        if(++frame_count & 0x01)
        	htm_data[94]++;
	// Temp save Checksum
	CalcHTMChecksum(100);
	// Goto begining
        htm_state=5;
    break;
// Inverter Status
bool GS450HClass::statusFB()
    return statusInv;
Woodfie
Post by Woodfie »
Great work , and nicely built.😃👍 The Q211 will be an interesting variant for sure...I like.... it!!
Thanks for spreadsheet and code information.....and great to see that the Gen 4 prius inverters are getting closer to what the Lexus gs450h inverter is doing.
evbuilder
Post by evbuilder »
daleread wrote: Thu Mar 10, 2022 7:41 am I suspect the same data is in all inverters but probably grew larger through the generations
Well I feel a little silly. I've been trying to decode this as a SPI port. But it isn't one at all. "Synchronous Serial" so it has a Clock sent with it to get the bit rate, however the bytes are still encoded like asynchronous data - with a start and stop bit?! I hadn't seen that before.
First time using this logic analyser software. Here you can see the serial streams decoded as a normal asynchronous stream. I think it can quite happily be "sniffed" with a bulk standard serial port, set at 500kbps.
Which, again I am doubting myself, because the GS450H stuff is at 250kbps - is the Prius faster, or is 250kbps good enough?
Woodfie and I had decoded MTH data using the GS450H code modified to accept the 20 more bytes. I thought I was confident that the data had changed position. Here is what we came up with:
MTH Known: 0-119 bytes
dc voltages 100,101 102,103 was 82,83 stored as 0.5V (IQ1)
Water temperature 51
MG1 speed 10,11
MG2 speed 40,41
checksum 118,119
This mapping doesn't seem to line up with the logic analyser captures from Damiens github. So I'm going to have to go back to the bench and confirm this.
daleread
Post by daleread »
The GS450h htm is 80 bytes but the Prius Gen 3 htm is 100 bytes. ? ! - (mth GS=100, mth Prius=120).
This should align the GS450h 80 bytes with the Prius Gen 3 Inverter, or are u=you using Gen 4? (mth 120 bytes)
	Constant					4			1
	Constant					4	16	4	16
	Constant					4	37	4	41
	Constant					4	60	4	67
	Constant					25	62	4	73
	Constant							160	90
	CRC						37	78	95	98
	CRC						1	79	1	99
	Data Rx	Inc			1
	MG1 Speed	Hi		6			6
	MG1 Speed	Lo		7			7
	MG1 rpm		Hi		12
	MG1 rpm		Lo		13
	MG2 Speed	Hi		31
	MG2 Speed	Lo		32
	Water Temp	Hi		42			42
	Water Temp	Lo		43			43
	Water Temp	Hi		88
	Water Temp	Lo		89
	CRC		Hi		78			98
	CRC		Lo		79			99
daleread
Post by daleread »
In Damien's code its 250000.
Could your 500000 be rising and falling edges therefore x2?
A Serial port, I use FDTI, has the speed. Maybe you should connect the CTS, RTS, DTR, to the clock and sync for your data capture, to synchronise the start and stop of each packet..
The GS450h_vcu code has
Serial1.begin(250000);
As the data speed for the Sync Serial transfer.
FTDI Serial USB Cable.jpg (12.87 KiB) Viewed 8838 times
Use a FDTI "TTL-232R-5V" for sniffing, they are the best around,
https://ftdichip.com/products/ttl-232r-5v/
https://ftdichip.com/wp-content/uploads ... CABLES.pdf
https://au.rs-online.com/web/p/developm ... es/6877770
RS Part number 687-7770
HTH
daleread
Post by daleread »
This is what I have found, but not tested yet.
dc voltages 100,101 102,103 was 82,83 stored as 0.5V (IQ1) - 82,83=102,103
Water temperature 51	was 42,43 is still 42,43
MG1 speed 10,11		was 6,7 is now 6,7
MG2 speed 40,41		was 37,38 is now 38,39
checksum 118,119	was 98,99 is now 118,119
Woodfie
Post by Woodfie »
Woodfie wrote: Thu Mar 10, 2022 10:11 am Will get driveline pictures in daylight.
Three Siris Roadsters were made, and four predecessors called Aurora Coupes. Not quite production, intention was to make available as a kit, or component car.
Woodfie
Post by Woodfie »
Sorry picture inverter, corrected , lost it all, adjusted alignment, and still have it downside up.☹
daleread
Post by daleread »
Its a cool looking car, I bet it goes like stink.
Thanks for sharing. What wheel pcd are you running?
And do you have any pics of the front suspension, I might be able to help a bit there?
Woodfie
Post by Woodfie »
daleread wrote: Fri Mar 11, 2022 10:32 am Its a cool looking car, I bet it goes like stink.
Yes , It goes rather well, weighing 750kg empty, and appears to level hills to make it feel like the world is flat.
The act of fitting the Q211 , Hylander MG unit, as a front drive has only just become a reality, with the great efforts and help of Damien's Lexus_vcu, and/or Johu's T gen2 MG2 logic drive input.. Many thanks to them and this forum....Awesome way forward.....THANKS GUYS ..
Back to the associated mechanics ...PCD is 4.5 inches
It maybe possible to modify the subframe to allow drive shafts to passage from the Q211 to some other hub uprights, use another frame, as MGF as you suggested or custom build a new frame. Because of the Q211 electric motor "Bump" out front of the wheel centerline, the steering rack could be in the way...to be determined..
Woodfie
Post by Woodfie »
Torsion, or double springs to clear the drive shafts required.
evbuilder
Post by evbuilder »
daleread wrote: Fri Mar 11, 2022 7:47 am In Damien's code its 250000.
I'm just saying what this logic analyser told me.
The tests with Woodfie we changed the numbers to 100 and 120, and moved the checksum to 118,119 (counting from 0).
Oh by the way - you've labelled it CRC, but what I am seeing is definitely a checksum, not CRC
daleread
Post by daleread »
Woodfie
Front Suspension photos from MGF and used in RS200 to get front drive.
You could keep your suspension arms, take out the shock/spring and build a small tower, then put the shock/spring on top of the top arm.
Then change the stub axle for the MGF one.
It will also fix your steering.
daleread
Post by daleread »
CRC = Cyclic Redundancy Checksum, sometimes a polynomial.
For the Toyota/Lexus its just adding up all the bytes and throwing away the over flow above 65535
daleread
Post by daleread »
Front (Nissan Leaf Motor) setup with MGF hubs, driveshafts, steering
I will be building this over the next few weeks with a Q211, I have the chassis ready, will keep you posted
Woodfie
Post by Woodfie »
Daleread
Thanks for the very informative info.
On the last drawing front on, what is the diameter of the green circle? as it closely indicates the height of lower inner suspension bushes to the top of the bonnet,
Thanks W
daleread
Post by daleread »
Here are the dimensions of the RS200 for you
The the 605mm can be reduced to fit under your bonnet line, but the RS200 is similar to your car for the bonnet line.
The cross bar locks it al together.
The steering rack is moved to the back to give clearance for the MGR motor unit.
Woodfie
Post by Woodfie »
Thanks for that, did a quick check to the outside top of my bonnet line, and is 550mm, presently have an inner panel, with moulded in spare tyre space, which would have to be dispensed with.....the 645mm would have to come down to around 500mm if the inner panel remained, could be a bit short for the coil over shock.
Looking favourable to have double springs to the lower arm, then would have to use hub assembly with lower ball joint designated to take load as cortina does.
