Wanted: Volvo / Eltek chargers
boekel
Been thanked: 30 times
Post by boekel »
I'm looking for multiple Volvo / Eltek chargers for a boat project on a budget...
Volvo IP67 charger can be found under those PNs
31394702
30659929
31453939
must include the water cooling baseplate.
Been thanked: 411 times
Re: Wanted: Volvo / Eltek chargers
boekel wrote: Mon Feb 14, 2022 9:33 pm I'm looking for multiple Volvo / Eltek chargers for a boat project on a budget...
31394702
30659929
31453939
You could get the IP20 version here:
https://www.aliexpress.com/item/1005002 ... mainSearch
And make your own base plate for two of them, put a watertight lid over them from each side. That was my first thought.
That way you could use 4 of them...
boekel
Post by boekel »
Thanks again, didn't look for air cooled ones :)
ordered some of these:
https://www.aliexpress.com/item/1005002802794429.html
boekel wrote: Tue Feb 15, 2022 10:05 am Thanks again, didn't look for air cooled ones :)
Well if you read both instructions closely you will notice that minimum energy dissipation is the same for IP20 as well as IP67 version. Both are cooled out via side alu plates towards lower alu plate. About the only trick is how to seal out the moisture.
I literally put the ip20 module into ip67 box... with some milling... and it works!
m.art.y
Has thanked: 38 times
Post by m.art.y »
This Eltek looks like a nice charger I was also considering using 6 of these in my car but decided against it in the end. The ip67 ones are expensive and the ip20 ones reguire custom cooling solution anyway plus the added complexity of wiring 6 of these together. I found out that using Tesla gen3 18.5 kw charger can be a more cost effective and simpler solution.
boekel
Post by boekel »
Unfortunately I was only able to buy 4 of the air-cooled chargers trough ebay / aliebaba
It seems they all come / came from the same source and there weren't as much available...
Does anyone have charger(s) they are willing to sell? I've already build a nice housing for them :(
pablo_mtl
Has thanked: 6 times
Post by pablo_mtl »
Holy smoke! That enclosure is very nice! Great job! :D
What's the plan to talk over CANbus with multiple Elteks with the same IDs? Can they be reprogrammed to other addresses?
boekel wrote: Sun May 29, 2022 6:13 pm Unfortunately I was only able to buy 4 of the air-cooled chargers trough ebay / aliebaba
I would advise you to put one alu collant block between chargers 2 on top and 2 in the bottom. That would be perfectly capable of keeping them cool.
Then you can go and completely close the box for IP68 standard.
boekel
Post by boekel »
pablo_mtl wrote: Mon May 30, 2022 12:56 pm What's the plan to talk over CANbus with multiple Elteks with the same IDs? Can they be reprogrammed to other addresses?
Yes, can't do that myself but I have some people in mind to hire for that job ;)
boekel
Post by boekel »
arber333 wrote: Mon May 30, 2022 1:00 pm
in this case the location they are mounted is dry, so no problem with aircooling.
