SAAB 96 with Yaris inverter / Smart ED3 motor / LEAF 96s2p battery
moebelschmitt
Has thanked: 82 times
Been thanked: 6 times
Post by moebelschmitt »
Hello everyone,
I'm new here and would like to introduce myself and my project so that you and I can learn from each other. My name is Peter, born in 1981 and I live in Hamm/Westfalia. I own a small vintage vehicle collection aka MÖBELSCHMITT. When I introduce my conversion project, I first have to tell a short backstory. Originally I wanted to equip a homemade Rat Rod with the components from a crashed Smart ED3. Not street legal, but as a toy and experiment to familiarize myself with the topic of electric vehicle technology.
However, for various reasons the project did not progress beyond stripping the Smart and transplanting the components into the 'Elephant'. In addition, I wasn't able to test run it yet because the battery was missing when I bought my Smart (rental battery).
Later, I recognized that the Smart components would fit perfectly into my 1962 SAAB 96, which I had acquired in the meantime, both technically and structurally. The SAAB 96 is small, light and aerodynamic. Vehicle specs of the Smart ED3 are very similar to the SAAB's: drive train setup, power, weight, etc.
However, I'm actually an architect and I have only little knowledge of electrical engineering or programming. I want to make the SAAB street legal here in Germany and for that I would have to prepare everything very well. And so I developed a plan.
I'll drive double track. First, I will restore the SAAB with the two-stroke engine and bring it to the technical inspection so that it is street legal for Germany (Swedish origin). At the same time, I continue to deal with the technology from the Smart. I've already gathered a lot of information and research. But the Smart technology is not very popular among DIY builders, which probably has its reasons ... For example, I found the Illuminati Motorworks open source project Smart ED3, but they also found their limitations. Jehu Garcia also once tried to work with an ED3, but at some point its trace gets lost ...
Still, I'm optimistic (until I'm convinced otherwise). And if anyone of you have recommendations for me, I'll be very grateful.
I will keep reporting. Stay tuned!
Peter
1962 SAAB 96 electric conversion project (Link)
instagram.com/moebelschmitt
www.möbelschmitt.de
MrJo
Re: SAAB 96 conversion with Smart ED3
Post by MrJo »
Nice project! The car looks like it is in great condition.
I drive my electric red Saab 96 1962 (that looks like it has escaped from the junkyard compared to yours) almost every day!
They are really fun to drive, even without a lot of power (I only have a “10kw bldc” motor in it.
Good luck!
moebelschmitt
Thanks, MrJo! My SAAB shows his choco side on this photo, but it really isn't that good. Enjoy your car!
In the meantime I have found that the Smart inverter is not suitable for modifications. Unfortunately, there are tear-off screws, glued and directly cooled components. At first I thought I might be able to use the case. But the internal geometry is complex and crisscrossed with cooling ducts. So I decided not to use this inverter. That in turn results in numerous other changes in my concept.
So, if you are curious to know what a Smart inverter A4519007502 (Continental EPF2-3) looks like from the inside and (like I) can't find any information about it on the whole wide web: This is the open inverter...
And now? My new plan is to use the Prius Gen3 Inverter with the OpenInverter Board. The Smart's AC motor should be easy to control with this. If anyone has any recommendations or experience with it, I'd be grateful for any advice.
Have fun with your projects, guys!
www.möbelschmitt.de
Been thanked: 1913 times
"open inverter" gets a whole new meaning :)
More TriCore + FPGA madness. What is the other power module used for?
I helped someone out running a smart motor with a gen2 prius inverter, which worked well.
moebelschmitt
Hi, everyone!
Yes, that's what it looks like (unless I know it would be "opened inverter").
Thanks, @johu for the tip about the successful use of the Smart motor.
Was it also a Smart ED3? My Smart is a 2014 ED3.
I'll try out with the Prius Gen3 Inverter. This would also be a solution for charging on board then, right?
In addition to my previous pictures, some more photos that show the internal cooling system and the directly cooled and glued power modules. Just to be documented. Very complex and highly integrated, but they cannot be disassembled non-destructively. I mean, you cannot even disassemble the boards without breaking up components.
I think the second (small) power module belongs to the 12V DC-DC converter...? But I don't know for sure.
I got a bit lost in the tangle, especially as I realized that this inverter won't be suitable :cry: :D
Enjoy your projects, guys!
www.möbelschmitt.de
moebelschmitt
Hello everyone,
After watching Johannes's latest YouTube videos from the Audi A2 and having learned a lot again, I want to present the current status of my design for the SAAB. As I decided to not use the Smart inverter, I changed plans and found some good informations about a setup with the Toyota inverter. I stole everything myself and then drew it according to the SAAB project. Some points are still open and I have to develop solutions for them. But I'm also very interested in what you think of it.
Next step will be to get in touch with a expert at German TÜV...
www.möbelschmitt.de
The mixture of Prius inverter and Smart motor will require you to measure emitted radiation (as opposed to a complete EMC test). I will send you a the contact of a knowledgeable man in Hannover.
If you haven't already read it: https://openinverter.org/wiki/Germany
Fenix
Post by Fenix »
Using an old two-stroke Saab is a great way to go in my opinion... I had a similiar idea but my 92 was in such good condition I'd like to restore it to original instead...
The roll resistance of these car is incredibly low, as well as the aerodynamics being great (together with a very small front area), making sure it will be a very efficient ev :)
moebelschmitt
SAAB 96 with Smart ED3/Yaris/MEB12s2p/solar
Hi there!
After a long break, I want to give a short update on my SAAB 96 project today. To be honest, at first sight I underestimated the scope of the conversion, but I'm probably not alone with that :lol: And as the wiki says somewhere, most of us tend to be mechanical rather than electrical or IT savvy.
First I had to complete a complex and long-term restoration of my Jaguar last summer and then started with the SAAB. I'm currently working on the bodywork and at the same time I'm preparing the conversion to electric drive with the Smart ED3 motor. I bought an inexpensive Yaris/Auris inverter and the matching V2b4 logic board from Damien and Johannes. The red LEDs are already flashing at 12V, but the 5V supply is not yet working due to a shortage of part MAX735CSA (IC14). Test run has to wait.
Meanwhile, I removed the reusable components and cables from my Smart ED3: electric motor, high-voltage cables, control cables and connectors, accelerator pedal, SOC instrument, cooling hoses, pumps, fans, etc.
No fancy CAN components, but simple little helpers for the big whole.
And I decided to use the SAAB's gearbox because there are fewer interface issues than with the Smart gearbox.
Countless video evenings and forum readings later, I feel a little more knowledgeable, but reasonably capable of tackling the conversion.
For example, the wiring and control of the inverter as a buck/boost charger has not yet become entirely clear to me. I would actually like to connect solar modules (in series 160V?) directly to the inverter via boost charging. I know it's slow, but that's okay for my purposes (occasional summer car) and it is also described as a possibility in the wiki. But I haven't found an example yet of how someone has done such a setup ...
And even with my battery solution using 4x MEB 12s2p modules and a DIY BMS, I only have a vague idea so far. Yes, I know that I know nothing. But still.
Here are a few impressions from work in the process and from my workshop.
www.möbelschmitt.de
moebelschmitt
Re: SAAB 96 with Yaris inverter / Smart ED3 motor / MEB 12s2p battery
Hello everyone!
After initial contact with the test engineer, I was unsure whether I should continue. The “EMV” particularly scared me. But apparently weaker rules apply to older cars (before 2002).
That's why I've researched more intensively in the last few weeks and continued to work on my plan. Maybe I'm on the wrong track. Maybe the project is beyond my technical and financial capabilities. But my curiosity and drive persist and challenge me. And I love this subversive idea of ​​the OpenInverter community and would therefore like to give back some of the knowledge and fun that I was able to experience in the countless videos from Damien, Johannes and many others by documenting my journey here.
My goal is still to convert the SAAB 96. But perhaps it makes sense to try out the whole principle on a less valuable car first and gain experience. That's why I want to first apply the plan to my small Renault Rapid/Express panel van. It was built in 1990 and is quite comparable to the SAAB in terms of size, weight and performance. I think he is the ideal candidate as a prototype.
Motor power, battery size, vehicle weight, cable lengths, installation space... The big challenge at the beginning is the lack of clarity of the data and sources, the equation with countless variables and the risk of investing time and money that will soon turn out to be a bad investment. My first idea for battery (VW MEB) would have been such.
Since I have to see things to understand them, I work graphically. But at least as important is an (honest) inventory of the performance requirements of the vehicle. Finally, the legal regulations in Germany, for example, require that the converted vehicle must be able to maintain a speed of 60 km/h on a 1 kilometer long gradient of 18%. It would be epic fail if the motor were too weak, the cables would get too hot or the battery was too heavy.
“EV Calculator” helped a lot. http://www.enginuitysystems.com/EVCalculator.htm
I calculated this in a excel:
And as we see: the smaller, lighter, cheaper solution is unlikely to meet the requirements. :roll:
Then I linked the most important variables that influence the system in a excel:
Then I calculated how I imagined charging. I'm putting DC fast charging on the back burner a bit, but I still want to plan for it. Solar charging is more for fun because I have the ambition (I know it’s not that easy):
With so many components and connections, I sometimes lose track. Especially because I had to do quite a bit of online archeology if you want to learn about the Yaris inverter and how to wire up. Never found a wiring instructions for 3-phase charge input e.g.
That's why I have two large, digital sheets. A sheet with an overview of the requirements:
... and a huge plan in which I record the connections:
For more details:
So, I'm currently working on the following questions. Any help is welcome :)
1. How much power loss should I expect from the Yaris inverter? 5% or rather 10% or even more?
2. Johannes explains in his Lab Update #55 that he does not use a line filter for reasons of space... But if I wanted to use one now, I would choose the 3-phase filter “FMAD-MRYB-2010” from SCHURTER, for example. However, this limits the input current to 20A, just like the coupling contactors. That would be acceptable, but are there better solutions?
3. When the 240/380V is plugged in, a relay "K1" should activate the inverter and thus close the coupling contactors. In the Wiki schema “Buck Mode Connection” there is a relay “APF30212”. Is this really a suitable relay for this purpose? If not, then which one?
4. I connect the three phases of the charging socket as follows L1-U, L2-V and L3-W. But where do I connect "Neutral" best?
5. Is the pin “CHA_AC_INPUT_RELAY” intended to control relay K6 or for K4 or which one?
6. What is the purpose of pin 27 “charger_hv_DC_request” ?
Best regards
Peter
www.möbelschmitt.de
moebelschmitt
Re: SAAB 96 with Yaris inverter / Smart ED3 motor / LEAF 96s2p battery
long time no see! I've made progress. But I'm dancing with the diva (FOC tuning)...
On-board/bench test with the following configuration:
Motor: Bosch SMG180/120 from Smart ED3
Battery: Nissan Leaf 40kWh 360V
Inverter: Yaris Gen3 No. G9200-52030
Logic Board: Yar_G3
Firmware version: 4.97.R-foc
Motor ran smoothly in sine mode the other day.
Then I connected the resolver and found out here in the forum that the Bosch SMG180/120 supposedly has 6 pole pairs.
Parameters:
polepairs = 6
respolepairs = 6
pinswap =„PWMOutput23“
All four sin/cos wiring combinations are producing similar full 360 degree angle plots by hand rotation. I wonder which one is correct.
Damien says: "in true predictable fashion of course it was the last one that actually works" ... But he does not explain how he did find this out in contrast to the other three possibilities.
I only get as far as start manual mode, entering manual id = 1A in the tuning procedure. The motor whines noticeable but doesn't rotate.
Still no finds in the forum and Youtube how to solve this issue properly. Watched Damien's and Johannes' FOC tuning tutorial like more than 50 times :lol:
Latuta too.
Any suggestions ?
Maybe playing with pinswap tomorrow ...
www.möbelschmitt.de
moebelschmitt
Good morning!
Yesterday I updated FW to 5.35.R-foc.
Then verified, my resolver connecting is correct (see table below) and experimented a bit with pinswap.
Pinswap = 9 didn't make a clunk!
Manualid = ​​up to 5A leads to whining, but no rotation, no glow from the bulb.
Starting at 6A, the motor starts to want to rotate.
But after less than a quarter turn, the 100W bulb lights up brightly and the motor stops.
I suspect I'm on the right track with the resolver and PWM.
But not yet confident enough to bypass the bulb, before seeing the motor makes some rev.
Is the high battery voltage causing the bulb to overreact?
Would it help to connect a second bulb in series? Or a different bulb?
Or should I just bridge the bulb now?
Here's a screenshot of my parameters+values:
Resolver connections Bosch SMG180/120 (Smart ED3) for documentation:
www.möbelschmitt.de
At some point the voltage sags so much through the light bulb that the current controller fully opens the taps and ALL energy is dissipated through the light bulb. At this point it is safe to remove it, the inverter has overload protection anyway.
What doesn't have overload protection is the motor, so run with a low-ish ocurlim (150A or so) to protect the windings.
moebelschmitt
Thanks, Johannes!
Today I did set ocurlim = 150A.
But later realized that pinswap = 9 wasn't correct after all. Clunk!
So I created a table with all possible pinswaps, because I literally have to have something like that in front of my eyes.
I determined pinswap = 10.
Then the motor ran at 6A and -6A in both directions. And also with the accelerator pedal in both directions.
The next step was FOC tuning, and I started setting syncofs in 5000 increments.
From syncof = 20000 on, the motor required increasingly more starting current.
However, it tends to run away after starting. That's why the 20A fuse blew twice because I couldn't reset manualid to 0 quickly enough.
At 22000, even manualid = 100A isn't enough.
Between 22000 and 23000, even 100A doesn't do anything. (I'm not sure I can enter more than 100A ?)
So the correct syncofs value is somewhere between 22000 and 23000. Or exactly 32768 apart.
Based on my table values, I decided to set syncofs = 22700 for now. Manualid = 0.1 and manualiq = 6A or -6A runs.
But would like to get it more in the right spot.
The motor now continues to run with the accelerator pedal for quite a long time, even after the pedal is off.
And directions are reversed ...
I'll continue tomorrow, searching around 55500.
Photo dump for documentation:
www.möbelschmitt.de
moebelschmitt
today I increased the syncofs value by +32768 and then again tried to find the ideal value.
There is a wide range between 55100 and 56700 where the motor wouldn't run with manualid≤120A.
I was too afraid to give more than 120A.
Ultimately, I set an estimated average value of syncofs=55468.
This makes the motor run very smoothly now and it doesn't run away any more.
Forward and reverse direction are correct now too.
However, it continues to make that unpleasant running noise, as can be heard in the video.
I don't know what's causing it. But it's certainly not right.
What can I do ?
Tonight I just used Numbers to calculate the median of my values.
So I'll try syncofs=55418 tomorrow. Seems to be more in the spot.
www.möbelschmitt.de
The angle noise floor is a couple of 100 digits, so no need to close in any further on syncofs.
The running noise could be electrical noise from the current sensors or something mechanical? Not sure how serious it is. My Nissan motor is a bit noisy as well when doing hill-hold. When spinning it's probably covered up by running noise.
moebelschmitt
here's a quick photo dump of my SAAB 96 conversion and my 'SolarXTender' (DIY solar storage trailer project) ...
Next time I will report in more detail.
Front battery box with 9 Leaf modules and SAAB 96 gearbox
Bench test of Yaris inverter and Bosch motor
Rear battery box with 9 Leaf modules (click to see full image)
Central battery box with 6 Leaf modules
Leaf BMS
Bosch Motor and cooling system
Yaris inverter and cooling system
Front Battery box on the engine hoist
3D printed 90 degree angle connectors for MG1 and MG2
SAAB 96 (before conversion started)
SolarXTender (17 kWh solar energy storage, 72V system, 400W onboard pv)
LiFePO4 battery of EVE 230Ah cells, mppt solar charge controller, 24s bms and 3000W/230VAC inverter
www.möbelschmitt.de
