Testing SDU inverter
- Peter
- Been thanked: 9 times
Hi Forum. Can the inverter (with Openinverter control board) be run without encoder for bench testing using a small 3 phase induction motor driven fan as load ?
Isaac96
Re: Testing SDU inverter
Absolutely! Just use 'start 2' to get into manual mode, then change fslipspnt, fweak, and ampnom as needed.
You'll probably want to follow this guide in the wiki:
https://openinverter.org/wiki/Schematic ... _the_motor
Just be careful to avoid overheating the inverter -- apparently they don't really like running without coolant because the thermal mass is low.
