I propose to the attention of all those interested and approved, the production of electricity using MG1 + MG2 from Toyota Prius 1 or 2.
The idea came to me trying to produce electricity using a PMG motor / generator driven by wind, water or ultimately a heat engine.
I was wondering if I could use the gearbox and the Prius converter to achieve my goal.
I understand that the Prius converter has several functions:
1. It has 2 inverters, the strongest capable of about 400A
Uses 1200 V IGBTs
2. It has a buck converter (seen from the inverter to the battery)
3. Does it have a DC / DC HV -> 12V converter that runs independently up to ~ 150V, up to 300V?
4. It has a third auxiliary inverter which also operates independently but is not yet clear
I want to use it, using a 32-pin plug with an external adapter.
Now I am asking the specialists if it is possible to adapt a new external module or reprogram one of the two that has already been done, such as: openinverter.org Brain Board Rev 3 - community edition
Toyota Prius ™ Gen2 inverter controller - community edition.
The intention is for the converter to charge the HV battery or a 12 v battery but with a large capacity of 220-500A or to produce direct three-phase or single-phase AC current, so that it can be used for home and home use.
I am waiting for your answers in this way!
