Testing platform
Has thanked: 455 times
Been thanked: 1771 times
Testing platform
I've browsed around a bit for a compact power module that would allow me for bench testing.
The best bang for the buck seems this: 450V, 20A, 113€
https://www.digikey.de/product-detail/e ... UR&lang=en
Thought maybe this could be of general interest
Jan
Re: Testing platform
Post by Jan »
Hi Johannes,
Have you used this power module yet? Do I understand it correctly as this would be a plug and play with V2 or V3 inverter kits?
Has thanked: 145 times
Been thanked: 369 times
johu wrote: Thu Oct 17, 2019 9:30 pm I've browsed around a bit for a compact power module that would allow me for bench testing.
I have with me here a small power section with unknown max rating 3 phase. Current sensors go to 50A. It was used to power AUX hydraulic pump in Opel Ampera. So it should be quite overrated.
Its interface is 5V level and described in Tom91 document in a thread here
https://www.diyelectriccar.com/forums/s ... stcount=85 and by myself here
https://www.diyelectriccar.com/forums/s ... stcount=84
I think this would be very suitable to you since everything is on hand. Even current sensors are there. Unit has its own chill plate and everything left to do is to hook up your signals and power. It should work from 40Vdc up to 420Vdc
I am sorry i dont have a connector for it though and the other one which is in my inverter i will need for my car.
If you want me to sent it to you by mail...
Update: the above mentioned board is obsolete, here is a new one: https://www.mouser.de/ProductDetail/Inf ... 9MRA%3D%3D
I might do project with it
