Model 3 PCS Controller Support Thread
fredd90
Re: Model 3 PCS Controller Support Thread
Post by fredd90 »
P.S.Mangelsdorf wrote: Sat Dec 11, 2021 9:07 pm
fredd90 wrote: Sat Dec 11, 2021 8:40 pm
P.S.Mangelsdorf wrote: Sat Dec 11, 2021 7:34 pm Alright so I've got my PCS wired up and no luck yet. Question: Do I need to change the PIN setting, and if so where do I find what my PCS needs?
Do you use software from Johu or Damien?
Have you followed the pinout in pdf at page one of this thread? I did my work on an original batterypack so i got the original cable with markings on each line.
Seems like the US and EU version got the same pinout.
Yes I have the correct wiring.
I'm not referring to the pinout. In the web interface, under the Version heading, there is a setting labeled PIN with a string of numbers. Does that setting need to be changed for each PCS?
Yes, if you bought the complete kit with software from Damien the PIN should be there but if you need a pin you buy it from Johu at openinverter.org...
The pin is just for the activation of the software, nothing to do with pcs, when I first started my controller the code was 8 numbers with comma. Then I got a new updated firmware.
Regardless it should work 5min without pin.
We still have some month of work left before it will work flawlessly i think.
P.S.Mangelsdorf
Has thanked: 323 times
Been thanked: 351 times
Post by P.S.Mangelsdorf »
fredd90 wrote: Sat Dec 11, 2021 9:23 pm Yes, if you bought the complete kit with software from Damien the PIN should be there but if you need a pin you buy it from Johu at openinverter.org...
Yeah, I bought the full kit.
I've got a US version. What should I be checking to get it working?
fredd90
Post by fredd90 »
When I got my pcs controller it did not work very well.
The dcdc worked when battery was fully charged but all the values was wrong, got a new firmware update then everything failed. Now 8 month later after many trial and error the pcs controller almost works, the charger won't start.
When I turn ignition on, then after my LDU is started and contractors closed. Ldu sends "inverter active" via can to my ecu then the relay enable 12v to input 1 at pcs controller.
Dcdc starts but the charger is still dead, some problem with bms messages i think.
P.S.Mangelsdorf
I'm trying to use the PCS essentially standalone, not looped in with other systems' CAN.
I'll get some screen shots of settings and spot values this morning.
fredd90
Post by fredd90 »
P.S.Mangelsdorf wrote: Sun Dec 12, 2021 1:21 pm I'm trying to use the PCS essentially standalone, not looped in with other systems' CAN.
Okay, same as me, just controller enable via input nr1, dont think there is something in the software to control precharge, therefore i connected my pcs hvdc parallel to engine inverter.
P.S.Mangelsdorf
So here's what I have verified:
- HV is being supplied to the charger, after 12V and via a ZEVA precharge
- 12V is being supplied to the charger
- There are copious grounds - The charge port ground is connected to the case and the control board, the 12V ground is connected to the case, board, and plugs
The only potential install issue is the comms port to the PCS, I hate those little pins and I'm going to try rebuilding the harness today to make certain everything is connecting properly, but I'm fairly certain it is correct.
The captures attached to this post are without the charge cable plugged in.
P.S.Mangelsdorf
And here are with the cable plugged in:
P.S.Mangelsdorf
It would appear to me that the board and PCS are not talking. Is that a correct diagnosis?
fredd90
Post by fredd90 »
P.S.Mangelsdorf wrote: Sun Dec 12, 2021 1:48 pm It would appear to me that the board and PCS are not talking. Is that a correct diagnosis?
That's also how my web interface looks when it's not "enable"
As fast as i "enable" via input 1, all readings came up and the "Opmode" turns to run.
Attached picture from pcs enable.
P.S.Mangelsdorf
fredd90 wrote: Sun Dec 12, 2021 1:59 pm
Ok this may be what I'm missing: Do I need to apply 12V to input 1? I hadn't seen that documented anywhere.
Right now the undesignated "input"s and "output"s are not wired to anything on my setup.
fredd90
Post by fredd90 »
P.S.Mangelsdorf wrote: Sun Dec 12, 2021 2:08 pm
Yes, I did not find any documents, just trial and error when I came up to 12v at input 1 enable pcs controller
P.S.Mangelsdorf
fredd90 wrote: Sun Dec 12, 2021 2:13 pm
Great, I will try that and see if that works.
P.S.Mangelsdorf
Ok input 1 helped, but still not quite there.
Its now entering run mode, but new weird-ness. When the car is plugged in, the charger report the correct voltage from the HV side (approx 317) but when it is not, its only reporting 25ish volts.
Its telling my evse to deliver power, but not drawing any amps.
Also dc-dc is not coming up at all.
Does input 2 need to be connected somewhere?
P.S.Mangelsdorf
See screenshots of voltages reported
Been thanked: 1913 times
Input 2 is currently unused. Have you set model to "US" ?
edit: cablelim reports as 0, why is that?
P.S.Mangelsdorf
johu wrote: Sun Dec 12, 2021 4:05 pm Input 2 is currently unused. Have you set model to "US" ?
Yes model is set to US.
Not sure why it did that time, I just retried twice and it showed 40, but no change in behavior.
Right after plugging in I get a whine from the charger (clarification) the PCS for about 5 seconds then quiet.
fredd90
Post by fredd90 »
Before we fixed the multiplexing error i also got very high acvoltage, and the uhv(dcvolt) switch between low and high voltage.
All this is solved in the last file Johu created, exactly the same issues that i got before:) (not yet officially released due to its not yet ready and fully working...)
When the whine is about 5seconds the pcs controller did my pcs not get the right values.
I can not start my dcdc alone if i chose type1 or type2. When I chose manual mode, i start the dcdc with input 1.
P.S.Mangelsdorf
fredd90 wrote: Sun Dec 12, 2021 5:43 pm I can not start my dcdc alone if i chose type1 or type2. When I chose manual mode, i start the dcdc with input 1.
Even in manual I'm not getting dc-dc
fredd90
Post by fredd90 »
P.S.Mangelsdorf wrote: Sun Dec 12, 2021 6:00 pm
You will not have that before the new firmvare
P.S.Mangelsdorf
fredd90 wrote: Sun Dec 12, 2021 6:01 pm You will not have that before the new firmvare
Two questions: could you or Johannes share the new firmware?
What is different in that firmware from the version Damien is using successfully, which I assume is what he installed on mine before shipping it to me?
P.S.Mangelsdorf
I tested with the new (unreleased) 1.03 firmware today.
This update fixed the bouncing around of the reported HV, but did not get the DC-DC or charging to function. Snips below of parameters, spot unplugged, and spot plugged in.
Any thoughts?
unplugged
plugged in
Try this one, it has a slightly modified 0x21d message (byte 0 is 5d instead of 2d). Will certainly NOT work for the EU version
stm32_pcs.bin
(18.27 KiB) Downloaded 357 times
P.S.Mangelsdorf
So after the update the version # did not change from 1.03, is that correct?
No luck getting dc-dc or charging
Screen shots below plugged in and unplugged.
Unplugged
Plugged in, manual mode
Plugged in Type 1 mode
Yes, I didn't update the version, guess I should have.
I really don't know what to do here as I only coded what had been reverse-engineered. I'm not sure which platform this would run at: https://github.com/damienmaguire/Tesla- ... r/Software . It's basically the open source version based on Arduino.
If anyone can do CAN logs in situ that would help
P.S.Mangelsdorf
johu wrote: Sat Dec 18, 2021 3:18 pm If anyone can do CAN logs in situ that would help
Possibly a dumb question, but I don't recall: is it possible to log from the web interface?
Locked
