Bi-directional throttle.
Riwi
Been thanked: 11 times
Post by Riwi »
Hi!
Is there a way to configure a bi-directional throttle in openinverter? I work mostly with conversions of boats and I use a industrial joystick, 1 axis, to controll fwd-n-rev and throttle.
In the Sevcon's i used there is a way to configure the throttle input so that a span on the voltage is for FWD another for REV and between them N.
Like this:
<----REV-->N<-- FWD---->
0v--------4v--5v-------10v
Is there a way to do the same with the openinverter?
Thank you
Rikard
Re: Bi-directional throttle.
Not right now, but since it is open source you could (have someone) add it. Source code can be found here: https://github.com/jsphuebner/stm32-sine
Riwi
Post by Riwi »
Thanks for the reply.
Riwi has sponsored that feature so it will be included in the next release :) Thanks very much!
yaroslav
Has thanked: 14 times
Post by yaroslav »
HI. Will dual throttle control be implemented?
Yes is implemented but only in source code
