Tesla front sdu max battery voltage!?
thetdiguy
Post by thetdiguy »
As the title states i was wondering how much voltage one would take reliably i have 12 A123 lifepo4 40v 12s modules i was planning 10 in series but at max charge voltage it would be 432v versus 388v for 9 packs would is take the 432 on the higher end ?
thetdiguy
Re: Tesla front sdu max battery voltage!?
Post by thetdiguy »
EV_Builder
Post by EV_Builder »
It's about the margin in regards to the fets in the inverter. If I'm correct they are 600Volts. So I think you can do that but I would monitor the battery voltage closely and ramp Regen accordingly with battery SoC etc.
thetdiguy
Post by thetdiguy »
I guess is it worth taking the risk for the extra .75 kwh module
EV_Builder
actually the issue is the bus capacitor that one is spec'd lower. In another thread this question came along too.
remy_martian
Post by remy_martian »
The Model 3 caps are rated at 430VDC. Not sure what SDU is.
I would not go with 10 modules unless someone (you have the unit - have a look) can confirm the caps are rated to 500VDC.
Friends don't let software friends do hardware design
Has thanked: 168 times
Been thanked: 350 times
You don’t have to charge the pack up to pack voltage…
EV_Builder
