- Bratitude
- Has thanked: 246 times
- Been thanked: 469 times
https://www.argenta-elektronik.com/wp/p ... e/?lang=en
Cad files for all the mod ice stuff. I started cleaning up and making a header that you just print and epoxy the pins into
- Gregski
- Has thanked: 631 times
- Been thanked: 1607 times
Awesome? I am clueless when it comes to CAD or 3D printing, so would you be able to make some and sell them to us?Bratitude wrote: ↑Mon Nov 08, 2021 12:46 am https://www.argenta-elektronik.com/wp/p ... e/?lang=en
Please and Thank You
- Bratitude
I could, yes I’ll post some photos in a bit here with the files and more info
- Gregski
- Gregski
meanwhile back at the Good Enuff Garage nothing fits, lol
- Gregski
Nothing our 2D printer can't modify...
- Gregski
that's better, hard to tell in the pics but the PCB sits all the way in now as the two 20 pin headers no longer hit the sides and slide 1/4" further back in
baby steps
baby steps
- Gregski
oh you have got to be kidding me mate
- Gregski
we're not done yet, but we're getting there, had to stop for the night as it started to rain outside and it was getting dark
please keep in mind we are not going for perfection, this is just a stop gap until the right header comes back in stock
- Gregski
I decided to purchase the "Engine Wire" harness which is the technical name for what we call the Transmission Wiring Harness on eBay for $250 bucks, expensive - yes, needed - absolutely! It's the green aka olive one below (I know that schematic/diagram is horrible, but Lexus never breaks it up into individual diagrams, and all the wire harnesses are always shown together... Epic Fail!)
Note: This wire harness does NOT come with the Inverter plug!
Harness Part # 82121-30E21 is for 2007-2010 (this is the one I bought)
$1,369 at the local Stealership
Harness Part # 82121-30E22 is for 2009-2011
$1,366 at the local Stealership
- Gregski
so first I laid it out and then I began to "thin" it out
this is as if you were standing in front of the vehicle looking down on the engine bay
part of this harness is a small completely separate Fuel Injector harness
so here it is again minus that Fuel Injector harness
- Gregski
I made the mistake of looking for the Inverter plug in the low resolution pics of the eBay listing, and you can easily mistake the two ECM Engine Control Module plugs (one is larger than the other) for the Inverter plug
- Gregski
the best way to try and identify this transmission harness in crappy pics is to look for this squigly plastic harness section that runs along the driver side of the transmission, it contains 4 plugs
1. MG1 Resolver connector (gray)
2. MG2 Resolver connector (gray)
3. Shift Solenoids connector (gray)
4. VSS Vehicle Speed Sensor connector (black)
- Gregski
on the other side of the transmission lives the Safety Neutral Switch (gray) connector
so in total we get 5 transmission connectors with this harness
- Gregski
but at the heart of this wire harness are the two complete home runs of the Resolver cables, one per motor
this is the transmission end, each plug looks the same (8 pins each)
However on the other end MG2 (black plug) gets two extra pins, these are for positive power leads for the Inverter
- Gregski
so here are those two Resolver cables separated from the Engine Wire aka transmission harness, this alone to me was worth $250 and you will understand once you attempt to crimp these to the plugs, ha ha
- Gregski
and here's all the crap we don't need from that Engine Wire harnesss
- Gregski
and here is all that we do need (we don't need that plug in upper left of the pic, I just kept it to keep everything together)
- Gregski
What's that? Did I make an excruciating boring video about the transmission wire harness? Of course I did!
- Gregski
with the transmission harness thinned out I quickly realized it take Two To Tango so I went out and paid $300 dollars for a $235 dollar Inverter harness official name is Engine Room Main Wire
Part Numbers:
82111-30K62 fits 2008-2009 (this is the used one that I just bought)
costs $7,144 new
82111-30K64 fits 2010
costs $6,341 new
Part Number: 82111-30K71 fits 2007-08
Part Numbers:
costs $7,144 new
costs $6,341 new
- Gregski
don't get too hung up on the part numbers many different part numbers will work/fit, the difference in part numbers does not only depend on the year of your Lexus but the options on that vehicle like what kinds of headlights it is equipped with, I am not making this stuff up, I spoke to a parts rep at the stealership
when I lay awake at night I justify overpaying by telling myself mine came with this handsome carrying case
- Gregski
so once again we turn to the craptacular Lexus wire harness diagram to identify the Inverter Harness aka the Engine Room Main Wire
Note: everything points to the light blue inverter harness
- Gregski
and yes this one comes with the coveted Inverter plug part number 82821-50640
- Gregski
anatomy of the Lexus GS450h Inverter Harness
- Gregski
and here is the star of our show, Mr. Inverter himself
