Inexpensive ACIM or IPM motor for testing
mdrobnak
Post by mdrobnak »
I'm looking for a small motor I can test my Volt / Ampera inverter with before purchasing the expensive motor, so I know I've got working components here... I just bought the battery cable so I can connect it up and actually give this thing a whirl.
Thoughts? Trying not to spend too much.
-Matt
Isaac96
Re: Inexpensive ACIM or IPM motor for testing
Post by Isaac96 »
An alternator will do the trick if you've got one around, just feed 6v to the coil. No position feedback of course, but it works well in manual mode.
Been thanked: 413 times
mdrobnak wrote: Tue Apr 06, 2021 4:55 am I'm looking for a small motor I can test my Volt / Ampera inverter with before purchasing the expensive motor, so I know I've got working components here... I just bought the battery cable so I can connect it up and actually give this thing a whirl.
-Matt
Hah! I can assure you whatever motor you decide on will be good enough for testing also. And Volt inverter is very good for cheap testing because it has such wide operating voltage band. Its drivers power supply work from 48Vdc up to 420Vdc you just supply 5V to its brain.
Once you decide on which motor you want to use you can just buy it and use it since motors dont care about what voltage or inverter you use. Of course within sane limits...
If you want another small project you can decide on ACIM motor - Buick Lacrosse e-assist motor 24261691
viewtopic.php?f=3&t=1032
Or you can choose Kia/Hyundai HSG motor which is PMSM 37390-03900
I am still working to make that one run... i dont see any problems besides that it uses up to 120Vdc and i want to use it with 360Vdc
Both motors are liquid cooled and come with resolver and are great for a small project like a motorcycle or 3wheeler.
EV_Builder
Post by EV_Builder »
Small 3-phase industrial motor. Those are also available with small wattage?
Like: https://www.ebay.de/itm/224641380369?h ... Sw7EFfa3P0
The question also depends on which tension levels you wanna feed it...
Has thanked: 479 times
Been thanked: 314 times
Post by MattsAwesomeStuff »
EV_Builder wrote: Mon Oct 18, 2021 12:47 pmSmall 3-phase industrial motor. Those are also available with small wattage?
... this is a 6-month old question.
EV_Builder
Yes; you are right. :o :geek:
