Wanted Leaf 30Kwh BMS
paaa
- Has thanked: 2 times
- Been thanked: 13 times
Hi Does anyone have a leaf 30kwh bms? Bought a 30kwh pack that has been messed with by a car dealer and they installed a 24kwh unit.
- Has thanked: 75 times
- Been thanked: 696 times
paaa
Re: Leaf 30Kwh BMS
There is a different number on the board and looks like some components but might just be different revisions , I'm comparing the two beside each other at the weekend and if the same will just send to dealer for obd bms update and I'll just record the can on the obd
- mike@indra
Re: Wanted Leaf 30Kwh BMS
yes we have one but from a high mileage used pack.
Director and Tech Lead at indra.co.uk
Mazda RX8, Soliton 1, 32KWH LiFePO4, Kostov 11alpha, Chademo. Running strong since 2012!
https://www.diyelectriccar.com/forums...iii-61556.html
paaa
Thats great , ill send you message on Facebook as was already talking to you about panther 120 gearbox and other bms units.
