STM32 woes
RetroZero
- Has thanked: 645 times
- Been thanked: 64 times
Re: STM32 woes
I assume the boards you have in stock on your shop site are all populated? Looks like I need another Prius Adapter board if I want to run MG1 and Mg2...
- Been thanked: 1918 times
Re: STM32 woes
Yes I will continue to sell only fully populated boards (minus connectors)
Re: STM32 woes
So I can get ahold of a few STM32s so I ordered 30 LDU boards without it and have it populated locally.
- rstevens81
- Has thanked: 29 times
- Been thanked: 114 times
Re: STM32 woes
Anyone know a source of stm32's rs just canceled my order, not in a hurry thou as it's just for a development board (mini hubner), at worst I can try and de solder off of a borked Prius board
Re: STM32 woes
You can get some off ebay, though I don't know if they're any good.
Yahha777
- Has thanked: 16 times
Re: STM32 woes
Hello! I will share my experience of buying STM microcontrollers on eBay. I bought 6 stm32 microcontrollers and 3 atmegs from https://www.ebay.com/usr/longsheng-electronic. Upon opening the parcel, microcontrollers with markings from different factories CHN 3 pieces and MYS 3 pieces were found in the packaging tape STM. In theory, they should be packed at the same plant and have the same manufacturer's plant marking. I was the first to install 2 controllers marked CHN on the board. AND! Oh joy! When turned on, the green LED blinked happily at once! How convenient, microcontrollers now come with Johannes firmware!
Re: STM32 woes
Wow, that's sketchy! Thanks for sharing. Hope I will receive mine soon, I ordered 10.
LRBen
- Has thanked: 122 times
- Been thanked: 290 times
Re: STM32 woes
PCBway have STM32F105RBT6 available at about $24 each with a 6-8 working day waiting time.
RetroZero
Re: STM32 woes
I have one still wrapped up from before Covid lockdown. Happy to post it if you are still interested Johu.
ps - will be picking up a second adapter board (minus molex) and brake booster board for the Golf project.
PM when you have a moment
Re: STM32 woes
So thanks to many part donations I should be able to supply Tesla LDU boards towards the end of next week.
- Been thanked: 1139 times
Re: STM32 woes
Well, my turn for the woes. Don't suppose anyone has a tray of STM32F107VCT6 lying around?
Re: STM32 woes
Is that helpful? https://www.heisener.com/ProductDetail/STM32F107VCT6 (probably not, another european-sounding Chinese broker)
Or any of the other suppliers listed on octopart: https://octopart.com/search?q=STM32F107 ... SD&specs=0
I don't recommend ebay, I ordered 10, tested 2, both broken. I suspect the other ones will also be.
Re: STM32 woes
Thanks Johannes. Will keep hunting. I'll skip ebay for sure:)
- Has thanked: 91 times
- Been thanked: 517 times
Re: STM32 woes
What was the problem with the ebay chips? Completely dead or strange behaviour?
Yahha777
Re: STM32 woes
In my case, all the microcircuits were in use with firmware on board and from different factories. I was able to flash 2 microcontrollers via SWD. In two, the SWD ports were occupied by the application and had to be removed from the board, soldered to the OLIMEX Н -103 board where there are jumpers and a JTAG connector. Through JTAG at a low frequency, it turned out to erase the memory and flash 2 more controllers. But my ST - link died after that. I think maybe such a thing will somehow help in checking and flashing suspicious products for those who have it on stream:https://aliexpress.ru/item/32699770295. ... 1628925361 Of course - this is China, but if this saves you from unnecessary soldering of the chip to the board, then it might be worth buying.
Re: STM32 woes
Reckon I'll buy 10 of these and pull off the mcus :
https://www.olimex.com/Products/ARM/ST/STM32-H107/
- Has thanked: 479 times
- Been thanked: 314 times
Re: STM32 woes
I thought you guys were sorted :/
There was a guy on reddit a few weeks ago who got a few thousand STM32s a year or two ago by mistake, for free, and between that and a few hundred of some other variety was liquidating them for what are currently massive discounts if someone wanted the lots. Was all Greek to me.
I'll see if I can dig it up, but I imagine someone eventually took him up on the offer.
- EV_Builder
- Been thanked: 37 times
Re: STM32 woes
If you buy from ebay only buy from sealed containers and original. I bought ST32's with the 100pins it's easier my mistake soldering then the ebay seller I guessed.
Re: STM32 woes
So LDUs are up again. Picked them up today and tested the first one good.
Re: STM32 woes
That's how desperate the situation is
- rstevens81
Re: STM32 woes
I have resorted to using these ...
https://uk.rs-online.com/web/p/microcon ... s/8029416/
Although I'm not as brave as you in desoldering them in my f103 zombie/stm32-car and created an adapter board for them
- mackoffgrid
- Has thanked: 6 times
Re: STM32 woes
Luckily, most of my electronics was sorted last year, just scraped through with my BMS. The last couple of boards are using old DUE and BLuepill I had lying around. I reckon I'll be going into CPU hibernation after this project.
Re: STM32 woes
My experience has been with the Microchip PIC processors. What I found is that parts more than about a decade old are slow, limited, and expensive. Newer offerings are faster, offer more peripherals, and are cheaper. I looked up the ST part number you're working with and it appears to be about 15 years old. Don't they offer something just as capable in a newer part number? At least with Microchip, they're suffering from the same shortage issues as everyone else, but are focusing more on stocking the newer parts than servicing legacy ones. Which means the family of ST processors you're using may not be available until 2023 (if ST works the same as Microchip).
I'm betting on the future!
