Motor Parameters
- Been thanked: 1913 times
Motor Parameters
Motor Parameters
by johu
In this section you will find parameters for a specified motor and inverter combination.
Read more...
by johu
Read more...
Re: Motor Parameters
Yes moved it the wiki. Link fixed
Does anyone have Motor Parameters for Ford Ranger, or similar Siemens motor.
I Know Damien played with a Siemens motor, but only without load?
- Been thanked: 1115 times
Yeah not much load on that motor
- hv_perfect1.txt
- (1.66 KiB) Downloaded 278 times
Added to wiki https://openinverter.org/wiki/Configuration_Files
Nice, thanks for the file.
I just automatically assumed you had a tesla drive unit, didn't know it was Siemens motor.
- Kevin Sharpe
- Been thanked: 10 times
Der Panzer has had multiple different motors/batteries as technology has changed over time
Will encourage everyone with a working and stable inverter/motor. To post or send the parameter file to johu.
With motor/inverter type and volt.
Yes or even better sign up here and post the parameters in the wiki
