Gen2 & rx 400h setup tip?
- celeron55
- Has thanked: 32 times
- Been thanked: 118 times
- Has thanked: 180 times
- Been thanked: 1109 times
Re: Gen2 & rx 400h setup tip?
fmax is quite low at 200 Hz. Means 3000 rpm.
I changed the fmax to 600 on the advice of Johannes, now there are no breakdowns and the revs have become much higher, which is what you need. It would be nice to reduce the current consumption without losing torque. What parameter should I decrease or increase to reduce ampere consumption? Thanks for the advice!
Tell us how you connected to the RX400 resolver?
We are solving a similar problem with an electric rear axle from Lexus.
We want to use GEN2 , but there are doubts about the accuracy of the perception of sin/cos signals from the resolver. We could not find a special signal processing unit of the resolver on the op-amp in the Gen2 circuit. Is a simple input divisor enough? Photos and diagrams will help us a lot. In the topic GEN2, a special scheme for processing resolver signals was discussed,is this scheme relevant on three op-amps?
Thank you in advance.
do not rush to judge hurry up to understand.
Dao
Dao
