Charging from Gen2 Prius?
Greetings to the guests of the forum. I really want to figure out if it makes sense to use the Gen2 inverter to charge a high-voltage battery. The answer to my question, I would like to hear from people who successfully use the Gen2 prius inverter as a charger for a high-voltage battery.Thanks for any help.
- Has thanked: 76 times
- Been thanked: 219 times
Re: Charging from Gen2 Prius?
There has been a bit of discussion on the topic here:
viewtopic.php?t=1070
So far it's all been bench tests.
It works, but the order of operation is critical. All the important information is in the topic linked by LRBen above.
