A bit longer than I expected to get to this, but I did go through all of them. Here’s my analysis.
Cirrun2.pcap - All valid. Current: 50 - 100A, Remaining Time To Bulk SoC: 17870 seconds, Remaining Time To Full SoC 69360 seconds
Cirstart.pcap: Has a startup (duh).
Charge Parameter Discovery
EV Cabin Conditioning: True
EV Error Code: NO_ERROR
SOC: 24%
EV Max Current Limit: 125A
Max Voltage Limit: 402V
Full SOC 100%
Bulk SOC 80%
*ALL GOOD!*
Cable Check Request - all good on your side. Note you are setting EV Cabin Conditioning and battery conditioning as true.
Current Loop - did you open your contactors in the loop? Station goes from 377 to 402V. No appreciable current flow. Not a great practice to open your contactors in the loop unless an emergency, and do send a power delivery request to shutdown. The station did not like this and went into emergency shutdown.
Cirstart2.pcap - another startup, looks like cirstart.pcap as far as messaging. Except you closed in at 193V when your pack is at 377V. Ouch! Don't do that! Your ramp to 50A looks fine otherwise. In the current loop you have maximum and target voltage set to 402V, ideally you should make your maximum higher than target.
Cirstart3.pcap - again closing in at way low voltage, 197V. Are you controlling this? Or does the LIM do it automatically? You'll get a pretty big current spike out of your batteries doing this. Ramp to 100A looks good. In the current loop you have maximum and target voltage set to 402V, ideally you should make your maximum higher than target.
Efacec1 - Efacec5 - current loop only, I see no issues other than max/target voltage.
Nice 126A in Efacec4! Shouldn't try to ask for more current than your maximum current limit though. A good station will fault you.
Efacecen.pcap - station went into fault, EVSE_Malfuction. Looks like you opened your contactors in the current loop without shutting down the station first (send power delivery request, then open contactors). Because of this, the station went to 420V even though you requested 0A, and shutdown. Some converters cannot operate without a load, and/or some output current. Be a good EV citizen and shut down properly, ok? You could potentially damage a station this way.
Efacaecst.pcap - Efacec startup capture. You closed in at around pack voltage this time, which is good. I see no issues here that aren't already covered above.
Ionity_fail1.pcap - No idea what's going on here. There's no high level packets in the pcap. And the MAC Ids here are not yours. I wonder if you (er, the chip) is picking up another station's PLC. Since you aren't going into SLAC, I wonder if you are not getting a good connection to the cable. Try holding up/supporting the cable until the lock engages. This is an issue in CCS1 markets with liquid cooled cables. You have a different port and a different cable than what normally causes this, but it's worth a shot. I would put a cheap scope on the pilot wire and make sure you have a solid connection. You should see the low level 1kHz square wave easily.
Other notes:
EVCCID is 0000[MAC in HEX]
Some stations take a while in charge parameter discovery, make sure you are using a state or flag to hold your Max voltage limit, not some sort of timer or anything.
