what should i use to pick up motor?
papasapien
i bought a nissan leaf 2013 whole motor assembly. and its gonna get dropped off. what should i use that will have the strength to pick it up the guy said i should rent a dolly from uhaul services. is that good enough to carry it around? should i get one of those?
- celeron55
- Has thanked: 39 times
- Been thanked: 136 times
Re: what should i use to pick up motor?
The whole stack weighs something like 120kg and can be easily disassembled into smaller portions. The motor is the heaviest in the stack and weighs maybe 60kg, so after a quick disassembly it can be carried by hand. It has some "safety screws" with different heads there, I recall center pinned torx, so make sure to have those or a good pair of Knipex to get them off.
Some kind of furniture dolly or hand truck sounds good though.
- JaniK
- Has thanked: 101 times
- Been thanked: 15 times
I have a "milkcrate dolly" that I use to move around my motors and other heavy stuff around, i got it because it had small dent and milkcrate or whatever didn't fit there anymore so it was junk to them, i just bent it back close enough and works fine for this type of stuff. Ask local grocery store about something with 4 wheels and taken out from use in The shop.
