- Fixed anti-windup issue, this could cause very strong unwanted regen in the upper speed range - SAFETY CRITICAL!
- Improved idc filtering for smoother DC current limiting
- add a parameter 'sincosofs' - this is the midpoint reading of a sin/cos encoder output, removing the requirement for a precise 1.65V midpoint and resistor divider if using, for example, a sin/cos chip that doesn't work on 3.3V VCC (MLX91204 requires 5V)
- Obey DC voltage limit in boost mode
- Disallowed saving parameters in run mode
- Added support for BMW i3 gate driver board SPI ADC
- Changed ADC sample time to 7.5 clocks
- Taking 8 samples from last PWM period instead of 3
- Rotor movement compensation becomes active above 10 Hz
- Auto-detect flash size and write parameters to according address
The release is here: https://github.com/jsphuebner/stm32-sin ... ag/v5.05.R
EDIT: the first bullet point affects FOC only
EDIT2: uncontrolled high rpm regen still not fixed, be careful.
