- Has thanked: 75 times
- Been thanked: 696 times
No it will be used with a Model 3 PCS for AC charging in the grey goose. Thanks muehlpower I had worked out the battery voltage but not the other parts of 0x112. Will update the DBC. 0x100 also seem to contain current.
0x3b4 byte 2 with no proximity 0x8c , with proximity 0x8d. I'm guessing this is how it detects a plug.
byte 4 0xb8 with no pilot, changes to 0xbe then to 0xb9 on standard pilot. Goes to 0xbc on a 5% fc pilot.
I'm not sure if this info was shared earlier in the thread, but attached page 126 (as marked on the bottom of each page) has some interesting info on the LIM (and charging in general)
i3-High-voltage-ComponentsGB.pdf- (4.5 MiB) Downloaded 1382 times
Thanks cloudy I have that. Updated the dbc with pilot detection from low nibble of 0x3b4 byte 4 :
0x8 : No pilot present
0x9 : AC pilot
0xc : 5% DC pilot
0xa : AC charging
0xd : CCS comms greenphy
0x9 : AC pilot
0xc : 5% DC pilot
0xa : AC charging
- muehlpower
- Has thanked: 17 times
- Been thanked: 168 times
0x100 is not received by the LIMJack Bauer wrote: ↑Wed May 26, 2021 2:02 pm No it will be used with a Model 3 PCS for AC charging in the grey goose. Thanks muehlpower I had worked out the battery voltage but not the other parts of 0x112. Will update the DBC. 0x100 also seem to contain current.
0x3B4 D4 low nible: status pilot
0=no pilot
1=10-96%PWM not charge ready
2=10-96%PWM charge ready
3=error
4=5% not charge ready
5=5% charge ready
6=pilot static
there are also locking status of plug and door and current charge mode (AC type1 /type2, DC) and the DC voltage on the connector (your signal on from the KLE)
- muehlpower
0x3B4 D7 DC voltage on CP x2V (0-500V) 0xFB means AC or negative DC, 0xFE error, 0xFC not available.
Excellent thanks. DBC updated. Turning out to be quite a nice module.
I have added an open task for a Wiki page :
viewtopic.php?f=18&t=1667
Scott166
Wow, I didn't check this for a week and you've done so much, so the wires I was trying to read are the wrong ones? I'm going to have to try and read and understand this thread all over again now
Restoring and converting a Classic Mini, I have mad ideas, semi sensible ideas and NO idea if I’ll ever get it done
Scott166
Thanks DamienJack Bauer wrote: ↑Wed May 19, 2021 1:44 pm Update : Seems PT-CAN1 goes to the car via connector X558 3B under the bonnet. Could be an easy point to get access by back probing the connector.
Update 2 : Wire colours. RED=PT-CAN-L , Blue/RED = PT-CAN-H
Sorry I've not been on this, work has been busy and kids football etc stopping me from getting on with it.
I'll try again Saturday
- Bratitude
- Has thanked: 222 times
- Been thanked: 413 times
Wiki page started here: https://openinverter.org/wiki/I3_fast_c ... M.E2.80.9D
Yep its easy to get to PT-CAN under the bonnet. I'll start filling out the wiki. Appreciate the help:)
- EV_Builder
- Been thanked: 37 times
This is flying! I'm in! I discovered that at 900metres from my house there is a public CCS charger ...
On the parking
of a camp-site...
Guess I need to order the 'club card' for it ..
Welcome aboard. V2 of the arduino due sketch now on the repo. Have almost work out all the signals in 0x3E9. This is where all the action happens.
So a little bit of info. The LIM will engage AC charging if the DC contactors are missing but not if the signal from the HV voltage detect circuit is missing.
- muehlpower
is the DBC file for the 2013-17 model or 2017+? because i have found some differences to my records.Jack Bauer wrote: ↑Fri May 28, 2021 11:22 am Welcome aboard. V2 of the arduino due sketch now on the repo. Have almost work out all the signals in 0x3E9. This is where all the action happens.
Well my logs are from a 2014 and 2015 model so far and my lims are 2014 and 2017 so that's what I'm working from. Not surprised if it changed with the newer batteries in later models.
One thing I did notice is my 2014 has a rather nasty hardware flaw. If the charge plug is inserted and you kill the 12v supply it kicks the evse on! Does'nt happen with the 2017.
- muehlpower
I read something about an emergency charge function in case the 12V battery is empty.Jack Bauer wrote: ↑Fri May 28, 2021 2:30 pm One thing I did notice is my 2014 has a rather nasty hardware flaw. If the charge plug is inserted and you kill the 12v supply it kicks the evse on! Does'nt happen with the 2017.
page 127.
the main difference I found is the variable for DC_I_ target. 10bit vs. 8bit or 1000A vs. 250A.
2017 LIM wired into the Grey Goose and tested working on AC. Next up integrating it into the VCU and canbus then DC experiments begin:)
Question : Can someone please tell me with LIM stands for?
Started roughing out a crude due program for dc. Still a lot to figure in the relationship between 0x3e9 and the additional 0x2f1 and 0x2fa used in the DC mode. Also updated the dbc with soc value in 0x112.
- larsrengersen
- Has thanked: 13 times
- Been thanked: 30 times
First an opportunity to say: amazing work, thanks for sharing all this.
ladegerät interface module perhaps?Jack Bauer wrote: ↑Sat May 29, 2021 5:38 pm Question : Can someone please tell me with LIM stands for?
My pleasure:) Kind of amazed really that this module has been around for so long without being hacked...
- EV_Builder
I bought a 2018 version. It was compatible with all cars except the 120ah version. That LIM version wasn't compatible with the other cars.muehlpower wrote: ↑Fri May 28, 2021 1:14 pmis the DBC file for the 2013-17 model or 2017+? because i have found some differences to my records.Jack Bauer wrote: ↑Fri May 28, 2021 11:22 am Welcome aboard. V2 of the arduino due sketch now on the repo. Have almost work out all the signals in 0x3E9. This is where all the action happens.
Can you please clone the DBC file and add the differences?
If the CANId is different then we should add it to both versions.
As soon as this info spreads we soon will know the why and how atleast the work is then done.
Wish I had my car built / ready for this phase...
bitterandreal
- Has thanked: 3 times
Very nice work!
I played a few times with the Advantics CCS module in the past months and learned a lot about the different charging standards.
I'm wondering if the newer LIM's do ISO 15118 AC and DC charging or only DIN 70121 for DC and J1772 for AC?
Would be interesting to test if features like plug and charge or even V2G (bidirectional power transfer) are supported by the LIM?
By the way, the German BMW dealers call it "LIM Lade-Interface-Modul Steuergerät" => Charge interface module controller
