Instagram CCS
Has thanked: 10 times
Been thanked: 335 times
Instagram CCS
Sooo as you know whenever I post something about Chademo the internet wants to know why I'm not doing ccs. This time I asked the internet and this time it responded. Aparaently this is all we need :
https://a.aliexpress.com/_9j6red
plus a microcontroller equals instant ccs...
Isaac96
Re: Instagram CCS
Post by Isaac96 »
They say non professionals are not allowed to buy ! !
So when you retire to Lanzarote you can't have them anymore.
v-proto
Re: Instagram CCS
Post by v-proto »
I already bought them and received them.
Re: Instagram CCS
Sweet. Any progress to share?
Has thanked: 403 times
Been thanked: 260 times
Re: Instagram CCS
Post by MattsAwesomeStuff »
Isaac96 wrote: Fri May 14, 2021 7:58 pmSo when you retire to Lanzarote you can't have them anymore.
I did some digging, and apparently this Lanzarote is a real place.
But I've been doing the math and you know what? I don't think Damien is going to have enough money to disappear with all his illegitimate gains and retire there. I don't think it's even close. He's been lying to us all these years. What then is his *real* motivation for helping all these people design and build their own EVs? Who's really pulling the strings here?
v-proto
Re: Instagram CCS
Post by v-proto »
Everything is very simple, you need a good programmer and he will write the code for controlling the charging and the consumer under the STM
Re: Instagram CCS
Well I like simple:) Can you confirm that using the hardware from Aliexpress you have implemented a CCS session successfully? I'm guessing the details are not available but even that much information would help the effort.
mikeselectricstuff
Re: Instagram CCS
Post by mikeselectricstuff »
Is the datasheet for the QCA7000 available?
Also, the line interface looks like it's aimed at powerline applications, probably differential - might needs some mods for the single-ended CCS application. Shouldn't be too hard to compare the coupling circuit on the board with one on a car CCS controller though.
Update - just saw there are multiple options on the listing, including QCA7005/EVSE configured.
v-proto
Re: Instagram CCS
Post by v-proto »
Jack Bauer wrote: Sun May 16, 2021 8:39 am Well I like simple:) Can you confirm that using the hardware from Aliexpress you have implemented a CCS session successfully? I'm guessing the details are not available but even that much information would help the effort.
By hand is very simple setup connection with car or station. But then you need to send command very fast. ;)
Re: Instagram CCS
Thanks. Bought a qca7000 car side module. Will look sexy on my desk if nothing else...
v-proto
Re: Instagram CCS
Post by v-proto »
qca7000 Can work as car and ev sive.
Switch just by register.
Re: Instagram CCS
Has thanked: 370 times
Been thanked: 1547 times
Re: Instagram CCS
Seems this is just implementing the physical layer as it expects full Ethernet frames on its serial data inputs.
Re: Instagram CCS
But....but...it's supposed to be simple...
Re: Instagram CCS
It has arrived. So the plan :
Step 1 : Buy cheap aliexpresss module
Step 2 : ???
Step 3 : Profit
mikeselectricstuff
Re: Instagram CCS
Jack Bauer wrote: Tue Jun 01, 2021 2:28 pm Step 2 : ???
Oh that's easy :
Find QCA700x datasheet without having to sign NDA
Write/port complete 7 layer network stack
Implement CCS protocol (includes making decisions on stuff that's ambiguous).
Repeatedly stab a voodoo doll you made of the IT dweeb who thought that as it's a "power" application, it would be appropriate to use an insanely complex, un-sniffable, un-scopeable wierd-ass protocol for a system that needs to have two devices talk to each other over a short, hardwired connection, just to agree how much current is needed, when 1-wire CAN would have worked just fine and saved everyone a whole ton of trouble.
Try not to look too suspicious whilst dicking around with a breadboard and laptop at your local charging station. At night. In the pouring rain.
Test on every different brand ( and firmware revision) of CCS charger you can find, trying not to die or need to call the fire brigade in the process
Deal with queries from noobs who've lashed up something with some 2.5mm twin & earth and are now wondering why things are melting
Step 3 : Profi.... Oh, hang on it's Open Source...er, bask in the glory perhaps?
Here's a diagram to get you started....
mikeselectricstuff
Re: Instagram CCS
..or if you value your time at any more than minium wage, figure out that it would be cheaper to "rent" an i3 off ebay & log the crap out of the LIM module
Re: Instagram CCS
Yeah I'm sticking with the LIM:)
Re: Instagram CCS
mikeselectricstuff wrote: Tue Jun 01, 2021 4:27 pm Oh that's easy :
That's hilarious :D But hey, some weirdos climb friggin Mount Everest for the fun of it. I'm thinking the death rate here could be lower. Though I'm not sure.
I would liketo crap on everyones doorstep that was involved in the design process. "So gentlemen, what is the most inconvenient transmission protocol for transmitting a few bytes?". "#1: How about FlexRay?" "Na, too easy". "#2: PLC?" "Not bad!" "A new variant of PLC so existing chipsets won't work?", "Yes! Perfect!". And it goes on. JSON? Bitbanging? XML? No! EXI! Every single design choice is just aimed at making developers life a nightmare. Amen.
EV_Builder
Re: Instagram CCS
Post by EV_Builder »
Is this still the effort worth? Since we have the LIM?
I think we should focus on the rest of the hardware suite :)
Ken_S
Re: Instagram CCS
Post by Ken_S »
Oh that's easy :
Keep in mind that CCS was created by a committee of engineering managers appointed by a bunch of companies who REALLY didn't want EVs to succeed when this was being designed. There is a reason why Tesla didn't go with the CCS standard for their DC fast charging protocol, and it isn't just that they weren't allowed to send anyone to the committee :?
Re: Instagram CCS
Came upon this today : https://github.com/devolo/dlan-greenphy-sdk
Is it what it seems?
Re: Instagram CCS
paaa
Been thanked: 13 times
Re: Instagram CCS
Post by paaa »
Wow nice find there1
