I have just started converting my VW Transporter from 85 to electric. It has the original petrol engine (1.9 liters 57kW) which works fine but I have been thinking a while about converting a car to electric drive and this car is perfect to do so. It doesn't weigh too much but has a lot of space and can carry a lot of extra weight.
I got hold of a used Tesla model S SDU for only 9500 SEK (950€) which I think is really cheap for such a powerful and complete motor. I also found a used Model 3 battery pack, 55kW, for 50000 SEK which also isn't too bad. They both have only been used between 10000-18000 km. I bought them both from Grønvolds bildemontering in Norway.
I got the things yesterday and we (me and my brother) started disessemble the battery pack and found 4 modules at 88.8 Volts. They are only 130 x 35 cm and about 50-60 kg which makes them very compact. They are also going to fit perfectly under the car.
I also installed the openinverter board for the SDU but I have to get some HV connectors because those wasn't included with the motor.
My plan is to use an Orion BMS 2 for the battery and charge them with an Elcon TC charger 6.6kW. I also hope that I can reuse the contactors that was included in the battery package, picture below.
Hopefully I will get the HV connectors and cables before next weekend so I can test the motor and controller.
/Johannes
