AURIS inverter Parallel MG1 and MG2 and DCDC question
invokeperformance
Post by invokeperformance »
Hello I just found out I have a Auris gen 3 inverter instead of a Prius. However I have a Prius gen 3 logic board kit. I can drive MG2 no problem and FOC tune. Can I still parallel MG1 and MG2 by connecting the six solder jumpers on the board in the same way as I would with the Prius gen 3 inverter?
Finally for the Auris inverter; in addition to the needed 350V CAP upgrade are the 210k DCDC resistor location values the same as the Prius inverter?
(Prius instructions shown below)
replace 4 resistors on the top side of the board, these are R629, R627, R625, R623, currently 120k ohm, these will need replacing with 210k ohm
There's also 4 resistors to replace on the bottom, these are R630, R628, R626, R624, these also need to be 210k ohm.
Thanks!
bexander
Has thanked: 78 times
Been thanked: 102 times
Re: AURIS inverter Parallel MG1 and MG2 and DCDC question
Post by bexander »
Are you able to fit the Prius logic board in a Auris? To my knowledge the Yaris/Auris logic board is smaller.
Anyway, you should be able to parallel the outputs (MG1 and MG2) in the same way for Prius Gen3, Auris and Yaris inverter.
If I remember correctly the Yaris/Auris DC/DC controller board is different from the Prius Gen3. There are still 4+4pcs of resistors that need to be replaced. They should all be located on the same side. Unfortunately I can't find the instructions on the forum but they should be here somewhere...
invokeperformance
bexander wrote: Fri Apr 23, 2021 6:21 am Are you able to fit the Prius logic board in a Auris? To my knowledge the Yaris/Auris logic board is smaller.
Yes the Prius logic board fits in the Arius inverter but not perfect, but all the signal connections can be made.
I am also unable to find the exact resistor change location on the wiki or forum I only need to modify DCDC to handle 360v-380v .
bexander
Post by bexander »
Ok, to my knwoledge there is a 11mm difference in length on the logic board between the Prius gen3 and Yaris/Auris inverter.
Maybe the information regarding the resistors for the DC/DC can be found in a video by Damien?
