When batteries are just too expensive...
https://thebolditalic.com/hacked-prius- ... cdbe55d68e
Prius running on trolley lines (2014)
- Bratitude
- Has thanked: 246 times
- Been thanked: 469 times
Re: Prius running on trolley lines (2014)
amazing. need more info! thanks for sharing
- Been thanked: 1918 times
And I'm screaming: that what buck converters are for!The overhead power lines put out 600 volts at around 400 amps ... The NiMh battery that does the heavy lifting in a normal Prius puts out 273 volts at 6.5 amps. Jon uses up the excess power on a whole lot of resistors
Pretty cool you can actually drive around in this, I bet in Germany they'd shut you down on the first day out.
