bobbyj_408
Posts: 88 Joined: Fri Nov 06, 2020 4:56 am
Post
by bobbyj_408 » Sun Mar 28, 2021 10:37 pm
Hi All,
I believe I got the SimpBMS software running on a Teensy 3.2, so I plugged it into my gen 1 Chevy Volt battery to read the cell voltages and I got the following (shown below). Now, the pack voltage from SimpBMS is 279.5 V, but I measured the voltage with a multimeter myself to be at around 339 V. There does seem to be an error readout from SimpBMS that says "!!! Series Cells Fault !!!", but how can I diagnose this? What do I need to do to fix this?
Thanks!
BMS Status : 1 Ready 80
Out:0000 Cont:0000 In:0000
Modules: 11 Cells: 80 Strings: 1 Voltage: 279.559V Avg Cell Voltage: 3.499V Low Cell Voltage: 3.056V High Cell Voltage: 3.543V Delta Voltage: 486mV Avg Temp: 13.066C
Module #1 21.24V Cell-1: 3.54V Cell-2: 3.54V Cell-3: 3.54V Cell-4: 3.54V Cell-5: 3.54V Cell-6: 3.54V
Temp 1: 9.09
Module #2 28.33V Cell-7: 3.54V Cell-8: 3.54V Cell-9: 3.54V Cell-10: 3.54V Cell-11: 3.54V Cell-12: 3.54V Cell-13: 3.54V Cell-14: 3.54V
Temp 1: 11.72
Module #3 28.31V Cell-15: 3.54V Cell-16: 3.54V Cell-17: 3.54V Cell-18: 3.54V Cell-19: 3.54V Cell-20: 3.54V Cell-21: 3.54V Cell-22: 3.54V
Temp 1: 10.52
Module #4 28.33V Cell-23: 3.54V Cell-24: 3.54V Cell-25: 3.54V Cell-26: 3.54V Cell-27: 3.54V Cell-28: 3.54V Cell-29: 3.54V Cell-30: 3.54V
Temp 1: 17.19
Module #6 24.72V Cell-31: 3.06V Cell-32: 3.09V Cell-33: 3.09V Cell-34: 3.08V Cell-35: 3.10V Cell-36: 3.12V Cell-37: 3.09V Cell-38: 3.11V
Temp 1: 11.49
Module #9 28.29V Cell-39: 3.53V Cell-40: 3.53V Cell-41: 3.54V Cell-42: 3.54V Cell-43: 3.54V Cell-44: 3.54V Cell-45: 3.54V Cell-46: 3.54V
Temp 1: 11.07
Module #10 28.30V Cell-47: 3.54V Cell-48: 3.54V Cell-49: 3.54V Cell-50: 3.54V Cell-51: 3.54V Cell-52: 3.54V Cell-53: 3.54V Cell-54: 3.54V
Temp 1: 10.16
Module #11 28.32V Cell-55: 3.54V Cell-56: 3.54V Cell-57: 3.54V Cell-58: 3.54V Cell-59: 3.54V Cell-60: 3.54V Cell-61: 3.54V Cell-62: 3.54V
Temp 1: 16.97
Module #13 21.23V Cell-63: 3.54V Cell-64: 3.54V Cell-65: 3.54V Cell-66: 3.54V Cell-67: 3.54V Cell-68: 3.54V
Temp 1: 11.46
Module #14 21.23V Cell-69: 3.54V Cell-70: 3.54V Cell-71: 3.54V Cell-72: 3.54V Cell-73: 3.54V Cell-74: 3.54V
Temp 1: 17.22
Module #15 21.24V Cell-75: 3.54V Cell-76: 3.54V Cell-77: 3.54V Cell-78: 3.54V Cell-79: 3.54V Cell-80: 3.54V
Temp 1: 16.84
CANbus 0.00mA 42% SOC 42000.00mAh
Posts: 2962 Joined: Fri Mar 01, 2019 9:15 pm
Has thanked: 329 times
Been thanked: 847 times
Post
by tom91 » Sun Mar 28, 2021 10:54 pm
As you can see from the read out it shows only 80 cells instead of 96, so issues with the cabus slaves. To get series cells fault to be removed you need to input the right series cell settings.
bobbyj_408
Post
by bobbyj_408 » Sun Mar 28, 2021 11:00 pm
Wow, thanks for the quick response. So it's possible that this is a configuration problem? That would be great. How do I set it to check 96?
Post
by tom91 » Sun Mar 28, 2021 11:55 pm
The displayed read out shows all the found Slaves, it would seem to me one of the slaves is not reading properly.
How have you wired it up? Did you retain the OEM loom?
bobbyj_408
Post
by bobbyj_408 » Mon Mar 29, 2021 12:27 am
Dang... I was worried about that. I noticed that one of the slaves has a dirt ring on it as if some water was on there at some point... I'm worried that I may have gotten damaged while it was sitting at the junk yard. Is there a way where I can individually check each BMS? Something like compare the battery section voltage with the voltage reported from the individual BMS slave?
Yup, OEM loom connected as specified in the SimpBMS manual.
Post
by tom91 » Mon Mar 29, 2021 8:19 am
I would say unplug each slave on the LV side one by one to identify the reported modules.
You need to find the one reporting module 6 as 5 7 8 are missing.
bobbyj_408
Post
by bobbyj_408 » Tue Mar 30, 2021 2:00 am
tom91 wrote: ↑ Mon Mar 29, 2021 8:19 am
Thanks Tom.
Did this and had some strange results. Still not quite sure which one would be defective...
Per the attached image, when I disconnected pack 1, I got the following
BMS Status : 1 Ready 0
Modules: 0 Cells: 0 Strings: 1 Voltage: 0.000V Avg Cell Voltage: nanV Low Cell Voltage: 5.000V High Cell Voltage: 0.000V Delta Voltage: -5000mV Avg Temp: nanC
CANbus 0.00mA 0% SOC -240000.00mAh
pack 2
BMS Status : 1 Ready 30
Modules: 4 Cells: 30 Strings: 1 Voltage: 106.226V Avg Cell Voltage: 3.541V Low Cell Voltage: 3.536V High Cell Voltage: 3.544V Delta Voltage: 7mV Avg Temp: 14.114C
Module #1 21.25V Cell-1: 3.54V Cell-2: 3.54V Cell-3: 3.54V Cell-4: 3.54V Cell-5: 3.54V Cell-6: 3.54V
Temp 1: 15.51
Module #2 28.34V Cell-7: 3.54V Cell-8: 3.54V Cell-9: 3.54V Cell-10: 3.54V Cell-11: 3.54V Cell-12: 3.54V Cell-13: 3.54V Cell-14: 3.54V
Temp 1: 12.07
Module #3 28.33V Cell-15: 3.54V Cell-16: 3.54V Cell-17: 3.54V Cell-18: 3.54V Cell-19: 3.54V Cell-20: 3.54V Cell-21: 3.54V Cell-22: 3.54V
Temp 1: 11.68
Module #4 28.31V Cell-23: 3.54V Cell-24: 3.54V Cell-25: 3.54V Cell-26: 3.54V Cell-27: 3.54V Cell-28: 3.54V Cell-29: 3.54V Cell-30: 3.54V
Temp 1: 17.19
CANbus 0.00mA 45% SOC 45000.00mAh
pack 3
Modules: 0 Cells: 0 Strings: 1 Voltage: 185.462V Avg Cell Voltage: infV Low Cell Voltage: 0.004V High Cell Voltage: 3.545V Delta Voltage: 3541mV Avg Temp: 14.216C
Module #1 15.48V Cell-1: 3.06V Cell-2: 3.09V Cell-3: 3.10V Cell-4: 0.00V Cell-5: 3.11V Cell-6: 3.12V
Temp 1: 15.44
Temp 1: 12.14
Temp 1: 11.72
Temp 1: 17.19
Module #9 28.31V Cell-31: 3.54V Cell-32: 3.54V Cell-33: 3.54V Cell-34: 3.54V Cell-35: 3.54V Cell-36: 3.54V Cell-37: 3.54V Cell-38: 3.54V
Temp 1: 13.73
Module #10 28.33V Cell-39: 3.54V Cell-40: 3.54V Cell-41: 3.54V Cell-42: 3.54V Cell-43: 3.54V Cell-44: 3.54V Cell-45: 3.54V Cell-46: 3.54V
Temp 1: 12.33
Module #11 28.34V Cell-47: 3.54V Cell-48: 3.54V Cell-49: 3.54V Cell-50: 3.54V Cell-51: 3.54V Cell-52: 3.54V Cell-53: 3.54V Cell-54: 3.54V
Temp 1: 16.97
CANbus 0.00mA 0% SOC 0.00mAh
pack 4
BMS Status : 1 Ready 38
Modules: 5 Cells: 38 Strings: 1 Voltage: 131.006V Avg Cell Voltage: 3.452V Low Cell Voltage: 3.060V High Cell Voltage: 3.544V Delta Voltage: 484mV Avg Temp: 14.050C
Temp 1: 15.70
Temp 1: 12.40
Temp 1: 11.94
Module #4 28.34V Cell-23: 3.54V Cell-24: 3.54V Cell-25: 3.54V Cell-26: 3.54V Cell-27: 3.54V Cell-28: 3.54V Cell-29: 3.54V Cell-30: 3.54V
Temp 1: 17.19
Module #6 24.76V Cell-31: 3.06V Cell-32: 3.09V Cell-33: 3.10V Cell-34: 3.08V Cell-35: 3.11V Cell-36: 3.12V Cell-37: 3.09V Cell-38: 3.11V
Temp 1: 13.01
CANbus 0.00mA 38% SOC 38000.00mAh
Post
by tom91 » Tue Mar 30, 2021 8:12 am
Pack 3 as it only shows 8 cells but the module is monitoring more.
bobbyj_408
Post
by bobbyj_408 » Tue Mar 30, 2021 4:41 pm
tom91 wrote: ↑ Tue Mar 30, 2021 8:12 am
Nice! Now the question is how to fix it? I suppose I could try finding a bms slave somewhere? I found one on ebay, but its part number is 22911432 and mine is 22880273. I highly doubt it's a good idea to mix and match like that...
I suspect opening up that BMS to see if anything is obviously broken is also a lost cause.
Post
by tom91 » Tue Mar 30, 2021 5:02 pm
Mind doing the following, unplug the HV sense wires one at a time till you find one that causes no change.
bobbyj_408
Post
by bobbyj_408 » Sun Apr 04, 2021 10:44 pm
tom91 wrote: ↑ Tue Mar 30, 2021 5:02 pm
Thanks Tom. I did this, and although there wasn't a connection that had no change, pack 2 did drop out module 6, which is the one we were looking for. I pulled out that bms, opened it up, and, well, I think the attachment speaks for itself. Note that this is the one that I mentioned that had the water stain on it.
Anyone out there have a replacement?
jon volk
Posts: 574 Joined: Wed Apr 10, 2019 7:47 pm
Been thanked: 3 times
Post
by jon volk » Mon Apr 05, 2021 4:49 pm
I had to replace 2 slave modules with similar corrosion. One of these days I plan on potting a set.
Posts: 7182 Joined: Thu Nov 08, 2018 10:52 pm
Has thanked: 552 times
Been thanked: 1914 times
Post
by johu » Mon Apr 05, 2021 5:19 pm
Seen that a lot in BMS context. I left one test system in the shed and there was a bit of water ingress. Looked similar. Water + high voltage + PCB.
bobbyj_408
Post
by bobbyj_408 » Mon Apr 05, 2021 6:19 pm
jon volk wrote: ↑ Mon Apr 05, 2021 4:49 pm
Oh man.. Where were you able to locate one of these? I assume they would be difficult to track down.
bobbyj_408
Post
johu wrote: ↑ Mon Apr 05, 2021 5:19 pm
Yeah... Looks like that's what happened here. Bummer.
jon volk
Post
by jon volk » Mon Apr 05, 2021 11:01 pm
bobbyj_408 wrote: ↑ Mon Apr 05, 2021 6:19 pm
They pop up on eBay all the time. Got a full set for $30.
bobbyj_408
Post
by bobbyj_408 » Tue Apr 06, 2021 12:23 am
jon volk wrote: ↑ Mon Apr 05, 2021 11:01 pm
Oh nice! Ok, I'll keep an eye out for that. I found a set that has 3 of the 4 boards available, but they have a different part number of 22911432, and mine is 22880273. I assume it wouldn't be a great idea to mix and match, right?
bobbyj_408
Post
by bobbyj_408 » Tue Apr 06, 2021 1:48 am
Actually, the seller did have all four of the 2291 part numbers. Should I just go for it?
bobbyj_408
Post
by bobbyj_408 » Sat Apr 17, 2021 10:55 pm
For those keeping tabs, I managed to find the BMS modules listed on Ebay. I got them in, installed them, and things look good! Reads all 96 cells, and output the same voltage that I read with a multimeter. The only thing is that the print out skips module 8, which I am guessing is why it says "series faul"? Any advice?
BMS Status : 1 Ready 96
Modules: 13 Cells: 96 Strings: 1 Voltage: 336.352V Avg Cell Voltage: 3.507V Low Cell Voltage: 3.076V High Cell Voltage: 3.546V Delta Voltage: 470mV Avg Temp: 13.890C
Module #1 21.23V Cell-1: 3.54V Cell-2: 3.54V Cell-3: 3.54V Cell-4: 3.54V Cell-5: 3.54V Cell-6: 3.54V
Temp 1: 9.32
Module #2 28.30V Cell-7: 3.54V Cell-8: 3.54V Cell-9: 3.54V Cell-10: 3.54V Cell-11: 3.54V Cell-12: 3.54V Cell-13: 3.54V Cell-14: 3.53V
Temp 1: 12.46
Temp 1: 12.56
Module #4 28.29V Cell-23: 3.53V Cell-24: 3.54V Cell-25: 3.54V Cell-26: 3.54V Cell-27: 3.54V Cell-28: 3.53V Cell-29: 3.54V Cell-30: 3.54V
Temp 1: 17.19
Module #5 28.32V Cell-31: 3.54V Cell-32: 3.54V Cell-33: 3.54V Cell-34: 3.54V Cell-35: 3.54V Cell-36: 3.54V Cell-37: 3.54V Cell-38: 3.54V
Temp 1: 10.49
Module #6 24.83V Cell-39: 3.08V Cell-40: 3.10V Cell-41: 3.11V Cell-42: 3.09V Cell-43: 3.12V Cell-44: 3.13V Cell-45: 3.10V Cell-46: 3.12V
Temp 1: 13.79
Module #7 28.29V Cell-47: 3.54V Cell-48: 3.54V Cell-49: 3.53V Cell-50: 3.54V Cell-51: 3.54V Cell-52: 3.53V Cell-53: 3.54V Cell-54: 3.54V
Temp 1: 17.10
Module #9 28.32V Cell-55: 3.54V Cell-56: 3.54V Cell-57: 3.54V Cell-58: 3.54V Cell-59: 3.54V Cell-60: 3.54V Cell-61: 3.54V Cell-62: 3.54V
Temp 1: 16.74
Module #10 28.34V Cell-63: 3.54V Cell-64: 3.54V Cell-65: 3.54V Cell-66: 3.54V Cell-67: 3.54V Cell-68: 3.54V Cell-69: 3.54V Cell-70: 3.54V
Temp 1: 12.20
Module #11 28.33V Cell-71: 3.54V Cell-72: 3.54V Cell-73: 3.54V Cell-74: 3.54V Cell-75: 3.54V Cell-76: 3.54V Cell-77: 3.54V Cell-78: 3.55V
Temp 1: 16.97
Module #13 21.23V Cell-79: 3.54V Cell-80: 3.54V Cell-81: 3.54V Cell-82: 3.54V Cell-83: 3.54V Cell-84: 3.54V
Temp 1: 13.30
Module #14 21.27V Cell-85: 3.55V Cell-86: 3.54V Cell-87: 3.55V Cell-88: 3.55V Cell-89: 3.54V Cell-90: 3.54V
Temp 1: 11.65
Module #15 21.26V Cell-91: 3.54V Cell-92: 3.54V Cell-93: 3.54V Cell-94: 3.54V Cell-95: 3.54V Cell-96: 3.55V
Temp 1: 16.80
Post
by tom91 » Sun Apr 18, 2021 12:10 pm
Check your settings in the battery settings, is it set to 96 cells in series and 1 parallel string?
bobbyj_408
Post
by bobbyj_408 » Sun Apr 18, 2021 10:06 pm
tom91 wrote: ↑ Sun Apr 18, 2021 12:10 pm
Ahh, looks like it wasn't! Below is what I have. I'll update this and let you know how it goes.
settings.Pstrings = 1; // strings in parallel used to divide voltage of pack
settings.Scells = 12;//Cells in series
dimonlipko
Posts: 47 Joined: Thu Apr 02, 2020 9:28 pm
Has thanked: 7 times
Been thanked: 11 times
Post
by dimonlipko » Mon May 02, 2022 8:35 pm
Someone check, is temp sensor measure true? I have big diference by temp in one battery. I think, Simp have problem in code for mach temp.
