Edit:
I'm adding this here so hopefully you will see it before attempting to open one of these packs.
I don't know if all eCar packs are the same but this pack has no physical safety disconnect to cut the pack in half, it will be at full voltage until you break it down.
It also means it is at full voltage while you are cutting the top off which is not easy and if you do it wrong you WILL cut into the battery modules!! I was lucky as before I figured out the best method I slightly cut into a module with my chisel but caused no harm.
The top of the pack is some kind of fibre glass covered in metal foil. It is so well glued down you will not be able to prize it off so will have to cut the top off.
To do this you MUST cut straight down at the corner of the bottom flange. Cutting flat in towards the pack will probably result in damaged modules and possible fire as unlike Leaf packs the modules have no protection.
I used a 1" wood chisel to cut the top off but I think one of those vibrating multitools would do it much cleaner and easier.
Even cutting straight down there are a couple of places where you could cut through BMS wiring so DO NOT use a Dremel or grinder to cut the top off.
I'll take some photos later and add them to this post.
Hi guys
I'm considering purchasing a battery pack from a 2020 e-Golf so asked some questions in the ebay thread and Bigpie kindly answered me so I thought it better to continue the conversation here.
This is the pack I'm talking about. https://www.evbreakers.com/product-page ... hv-battery
It's a 35.8kWh pack from a car with only 165 miles so basically brand new.
The cells are a mix of 15.2V https://www.ebay.co.uk/itm/VW-e-Golf-15 ... SwDgtfqRK5
and 7.6V https://www.ebay.co.uk/itm/VW-e-Golf-Mo ... Swn9Jf7dRx
If I have this right Bigpie says I can currently use the CAN connections in each module to monitor voltage and temperature but for the moment not balancing. This means I have to either fix the balancing issue or use a third party BMS.
If anyone else knows more about these battery packs then please share.
