Where to buy SDU Molex housing?
Johannes.l
Post by Johannes.l »
Hi! Does anyone know where to buy or if you can buy the plastic housing, for the mx150 20 pin, connected to to Small model s motor? Mine has been very brittle and was already a bit damaged when I got the motor. But I don't know what to search for.
Thanks!
/Johannes
Has thanked: 246 times
Been thanked: 469 times
Re: Where to buy SDU Molex housing?
digi key, mouser, eBay...
Johannes.l
Bratitude wrote: Fri Mar 12, 2021 3:49 pm digi key, mouser, eBay...
Well yes they might have but I don't know what part number I'm gonna search for. I've been looking around but haven't found this one exactly.
Johannes.l wrote: Fri Mar 12, 2021 7:11 pm
Okay quickly looking on molexs site, 3480____ are the right angle pcb mount connectors, there are 4 different key types. I’d just compare the keying of yours with the keying options. The one that match’s is it. now, there are a light grey, dark grey and 2 black.
That potentially narrows it down to 2 part numbers. 34802001 and 34802004. But it could be the other two, being Elon is a bit of a troll ..
PacEmaker
Has thanked: 5 times
Post by PacEmaker »
It's 'Keying B' type, so if it's a male housing it's Molex part 33482-2102. If it's a male header (PCB mount) it's Molex part 34830-2002. If you go to Molex and search these then click on the 3D viewer you'll see the keyway types match yours where it's broken. The stock pictures on Molex datasheets are useless and don't show that keying difference. Because you haven't shown the back of your connector I can't say if it a housing or a header type - from the angle you show it could be either. Check the 3D views and you will see, then search. If it's the housing type then I think Mouser said they will be available April 7th.
Geoff
Is this smoke trying to tell me something ... :twisted:
Johannes.l
I might only be stupid but I need a vertical one and not a right angled. :lol: Se the pictures below. I can only find the ones that you said but they doesn't seem to fit.
Thanks anyway!
PacEmaker
Post by PacEmaker »
Looks like a panel mount housing but what's going into the back of it? The way you describe it being 'straight not right angle' sounds like you're saying it is PCB mount at the back but without pics how can we tell?
It might be proprietary for Tesla, made by Molex? I wonder if you can send your pic to Molex and maybe they will help? You never know your luck ...
Geoff
Been thanked: 411 times
Usually Molex has part numbers etched on the side of connector. You need to look with LED light at correct angle.
Johannes.l wrote: Mon Mar 15, 2021 11:21 am I might only be stupid but I need a vertical one and not a right angled. :lol: Se the pictures below. I can only find the ones that you said but they doesn't seem to fit.
Thanks anyway!
Okay so that looks like a panel mount then, not the pcb mounted
PacEmaker
Post by PacEmaker »
The housing clips into the Tesla casting so I reckon that's made just for Tesla. The listed Molex panel mount ones don't do that and they max out at 12-pin, no 20-pin panel mount version listed. I reckon your best bet is to send a pic to Molex and pray that a good person there sends you the housing! Sometimes good people do good things, mostly they just toe the company line however...
Geoff
Johannes.l
Haha, yes I will try to send a mail to Molex. Thanks for the help anyways guys!
filiperosa
Post by filiperosa »
Hello, did you find any more information on this? I also have a broken connector that I need to replace.
EV_Builder
Post by EV_Builder »
Maybe it's time to draw it up and 3D print it?
Johannes.l
I was about to email Molex but you needed a company organisation number to do that so I just left it at that. Mine still works but it's very brittle so it might brake completely.
It shouldn't be to hard to 3d print it if you have the experience in CAD and a 3d printer, both which I don't have at the moment haha. I would be able to pay a small sum though if someone else tried.
EV_Builder
I can't print. Yet. The day I can I will take this up on me.
Proton
Has thanked: 227 times
Been thanked: 57 times
Post by Proton »
Broke mine too.
I think I found something:
https://www.newark.com/molex/34830-2001 ... irect=true
woutvanschaik
Post by woutvanschaik »
Anyone sure about the part? the one from Proton looked like the right angled one to me as well. If nobody has been able to find one i might as well print one. let me know
Converting a E21 to Tesla SDU
