PowerWatcher Display for Tesla
Has thanked: 75 times
Been thanked: 696 times
I'm pleased to announce cooperation with Yuriy Logvin, designer of the Powerwatcher Android display system, to integrate functionality for the open source Tesla drive unit and charger logic boards. I get asked a lot about a display for these products so it's finally on the way:)
The Powerwatcher will connect to the drive unit or charger or both over CAN and use any android device via bluetooth to display a vast array of information.
PowerWatcher website : https://powerwatcher.net/
The CAN firmware will be opensource so can be used to integrate other systems such as SimpBMS etc.
Obviously it will also be usable with any board running the openinverter firmware with CAN capability.
Estimated time to release 2-3 months.
Attached a few screenshots of a Powerwatcher running in my E36.
Kevin Sharpe
Been thanked: 9 times
Re: PowerWatcher Display for Tesla
Post by Kevin Sharpe »
That's great news :D
Has thanked: 455 times
Been thanked: 1771 times
Sweet! Is it a dedicated display or does it run on your phone?
Kevin Sharpe
johu wrote: Thu Jul 11, 2019 5:12 pm Sweet! Is it a dedicated display or does it run on your phone?
Android phone or tablet... here's the user guide;
https://powerwatcher.net/downloads/PW2_ ... ual_en.pdf
jon volk
Post by jon volk »
Ill definitely take one
x.l.r.8
Post by x.l.r.8 »
I've been waiting for this. excellent news
If somethings worth doing, its worth getting it wrong a few times first.
Yuriy has completed the pcb design for the can interface so will have prototypes for testing very soon.
Evtorque
Post by Evtorque »
Will these boards run up to 400v?
yes
Bare pcbs have arrived with Yuriy for the Powerwatcher V3 CAN interface. The V3 uses RS485 modules for sensing. In the picture you will see one with isolated voltage and current sensors attached.
Would be great if someone could put together a can message list that we can all agree on.
Has thanked: 264 times
Been thanked: 717 times
The SimpBMS battery can bus info is in the manual so please stick to that. As it is the same a few other BMSes out there so it can work with solar inverters/chargers.
CAN interface board prototypes built and tested and on the way to me. We should have it operational for Tesla / Opeininverter systems in the next few weeks.
CAN adapter schematic and firmware now on Github :
https://github.com/YuriyLogvin/CAN-RS485-adapter
zippy500
Has thanked: 83 times
Been thanked: 7 times
Post by zippy500 »
I know its marked for Tesla, but will this work for other home-brew conventional setups running 360v?
All openinverter based systems
Powerwatcher CAN interface has arrived. Don't suppose anyone wants to put together a can dbc that we can all use?
You could always use the Zero EV can messages for the DU as a base.
Currently populated two messages with the following
Thanks Tom. I'll use that as a template.
Ok then here is a stripped down DBC attached, also has the base Can info for SimpBMS and the open source Tesla Charger. I removed some info I received in confidentially.
Cannot upload '.dbc' that is why it is rar'ed
zeroev - Copy.rar
(1.24 KiB) Downloaded 439 times
New webshop for Powerwatcher products :
https://shop.emkit.net/shop
zippy500
Post by zippy500 »
Looks interesting.
I just looked at his power watcher 3 high voltage,
Max voltage 200v
Is this correct ?
Where did you see 200v for the powerwatcher 3? powerwatcher 2 was limited to 200v NOT powerwatcher 3. powerwatcher 3 can go to 450v.
jon volk
Post by jon volk »
Jack Bauer wrote: Mon Oct 14, 2019 7:45 pm New webshop for Powerwatcher products :
Just to confirm, the high voltage V3 kit currently in the webshop is ready to go for Telsa LDU compatibility, assuming the proper CAN messages are loaded?
Igor
Has thanked: 19 times
Post by Igor »
The webshop lists two different powerwatcher 3 kits. The lower priced "middle voltage kit" looks like it's limited to 200v.
@jon volk no not yet. Seeing as no one wants to bother making a list of can commands for Yuriy it's waiting on me.
