Gen 3 inverter converter control software
- Bratitude
- Has thanked: 168 times
- Been thanked: 351 times
Re: Gen 3 inverter converter control software
Possible to add in a menu to just control the buck/boost module?
Edit*
For dc charging from a variety of sources. Ie smaller battery pack, solar, wind, etc
Would have to isolate the module of course
Edit*
he second day I try to compile the Interfax WEB file (((constantly gives an error (((I tried to build it in arduino - and also failed (((please re-upload the files...
- Has thanked: 82 times
- Been thanked: 422 times
Whats your error?
Yea, your esp ip address wont be 192.168.1.20, that'll need changing to match your ISP, unless you've told it to join your network you will need to change to connect to the module wifi network and uss the 192.168.4.1 ip look in platform.ini you could also upload via the cable.
The photo shows a trial address ))) that's what you have to offer I also tried...I tried it -- the error is the same(((
Everything loaded normally) but does not work( what is the problem?
You also need to upload the filesystem.
Yes!!!! It worked.thank you so much for your help . Waiting for the updated files)))
You'll also need the code from my repo on the atmega for the params etc
These haven't been merged back yet, note I haven't charged a high voltage pack with it at the moment. Not sure if anyone else has.
I'm getting laptop out in a bit, I'll push changes.
Hi! I attach a photo .why there is no output of parameters . The board is not yet connected to the inverter...Should the parameters be output from Atmega when the inverter is not connected? Or am I in trouble?)))
It loads them from the Atmega, try typing 'params' without quotes, and hitting send, see if that loads them. It should issue that on loading.
Do you see the message come from the ESP in the browser developer tools? If you look at the web socket messages.
In the browser, here is the information after sending the command
no capital p.
I'm busy with some other stuff for a while, but I'll try and get set back up to make this more robust asap.
I'm going down the outlander charger route now as my battery pack voltage is too high for this with single phase, but will hopefully at some point reconfigure it to under 300V and do some proper charging with this setup but as this stands, I'll not be using it unless someone comes up with a neat way of using it on single phase on packs the > 340VDC batteries, as that is beyond my ability.
So what about the output of the parameters? What's my problem? I am interested in the charging varian in two versions-both from 3 phases and from one. And I am interested in this project .so fill in the updated files if you don't mind. Maybe there are Arduino files, it's easier for me to work with them, so to speak, more familiar. In any case, thank you for your hard work...
try typing params, all lower case and hitting send, I've noticed it not always loading them correctly when the page first loads.
